Datasheet Texas Instruments SN74AS576 — Даташит
Серия | SN74AS576 |
Octal D-Type Edge-Triggered Flip-Flops With 3-State Outputs
Octal D-Type Edge-Triggered Flip-Flops With 3-State Outputs datasheet
PDF, 1.3 Мб, Версия: B, Файл опубликован: 1 янв 1995
Купить SN74AS576 на РадиоЛоцман.Цены — от 74 до 1 076 ₽ 20 предложений от 17 поставщиков Flip Flop 1 Element D-Type 8 Bit Positive Edge 20-SOIC (0.295, 7.50mm Width) | |||
SN74AS576DWG4 Texas Instruments | 74 ₽ | ||
SN74AS576N Texas Instruments | от 329 ₽ | ||
SN74AS576DWR Texas Instruments | 1 076 ₽ | ||
SN74AS576DWG4 Texas Instruments | по запросу |
SN74AS576N | |
Статус продукта | В производстве |
SN74AS576N | |
N | 1 |
Pin | 20 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 20 |
Carrier | TUBE |
Маркировка | SN74AS576N |
Width (мм) | 6.35 |
Length (мм) | 24.33 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Parameters / Models | SN74AS576N |
3-State Output | Yes |
Bits | 8 |
F @ Nom Voltage(Max), Mhz | 125 |
ICC @ Nom Voltage(Max), мА | 135 |
Рабочий диапазон температур, C | от 0 до 70 |
Output Drive (IOL/IOH)(Max), мА | 48/-15 |
Package Group | PDIP |
Package Size: mm2:W x L, PKG | See datasheet (PDIP) |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | AS |
VCC(Max), В | 5.5 |
VCC(Min), В | 4.5 |
Voltage(Nom), В | 5 |
tpd @ Nom Voltage(Max), нс | 9 |
SN74AS576N | |
Бессвинцовая технология (Pb Free) | Да |
- Advanced Schottky Load ManagementPDF, 277 Кб, Файл опубликован: 1 фев 1997
Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme - Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
Серия: SN74AS576 (1)
- Semiconductors> Logic> Flip-Flop/Latch/Register> D-Type Flip-Flop
