Datasheet Texas Instruments SN74AVC16T245-Q1 — Даташит
Серия | SN74AVC16T245-Q1 |
Automotive 16-Bit Dual-Supply Bus Transceiver With Configurable Voltage Translation
SN74AVC16T245-Q1 16-Bit Dual-Supply Bus Transceiver With Configurable Voltage Translation and 3-State Outputs datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 6 июл 2016
Купить SN74AVC16T245 на РадиоЛоцман.Цены — от 29 до 497 ₽ 47 предложений от 28 поставщиков 1.2V to 3.6V, 16Bit dual-supply bus transceiver with configurable voltage translation and 3-state output_x0000_@ | |||
SN74AVC16T245DGGR Texas Instruments | от 29 ₽ | ||
SN74AVC16T245DGGR Texas Instruments | 29 ₽ | ||
SN74AVC16T245DGGR Texas Instruments | от 58 ₽ | ||
SN74AVC16T245DGGR Texas Instruments | по запросу |
CAVC16T245QDGVRQ1 | |
Статус продукта | В производстве |
N | 1 |
Pin | 48 |
Package Type | DGV |
Industry STD Term | TVSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | WF245Q |
Width (мм) | 4.4 |
Length (мм) | 9.7 |
Thickness (мм) | 1.05 |
Pitch (мм) | .4 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Parameters / Models | CAVC16T245QDGVRQ1 |
Bits | 16 |
F @ Nom Voltage(Max), Mhz | 100 |
ICC @ Nom Voltage(Max), мА | 0.06 |
Рабочий диапазон температур, C | от -40 до 125 |
Package Group | TVSOP |
Package Size: mm2:W x L, PKG | 48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) |
Rating | Automotive |
Schmitt Trigger | No |
Technology Family | AVC |
VCC(Max), В | 3.6 |
VCC(Min), В | 1.2 |
Voltage(Nom), В | 1.2,1.5,1.8,2.5,3.3 |
tpd @ Nom Voltage(Max), нс | 4.1,3.6,3.4,3.2 |
- Dynamic Output Control (DOC) Circuitry Technology And Applications (Rev. B)PDF, 126 Кб, Версия: B, Файл опубликован: 7 июл 1999
Texas Instruments (TI[TM]) next-generation logic is called the Advanced Very-low-voltage CMOS (AVC) family. The AVCfamily features TI?s Dynamic Output Control (DOC[TM]) circuit (patent pending). DOC circuitry automatically lowers the outputimpedance of the circuit at the beginning of a signal transition, providing enough current to achieve high signaling speeds, thensubsequently raises the i - AVC Logic Family Technology and Applications (Rev. A)PDF, 148 Кб, Версия: A, Файл опубликован: 26 авг 1998
Texas Instruments (TI?) announces the industry?s first logic family to achieve maximum propagation delays of less than 2 ns at 2.5 V. TI?s next-generation logic is the Advanced Very-low-voltage CMOS (AVC) family. Although optimized for 2.5-V systems, AVC logic supports mixed-voltage systems because it is compatible with 3.3-V and 1.8-V devices. The AVC family features TI?s Dynamic Output Control ( - Voltage Translation Between 3.3-V, 2.5-V, 1.8-V, and 1.5-V Logic Standards (Rev. B)PDF, 390 Кб, Версия: B, Файл опубликован: 30 апр 2015
- 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
TI?s 56-ball MicroStar Jr.E package registered under JEDEC MO-225 has demonstrated through modeling and experimentation that it is an optimal solution for reducing inductance and capacitance improving thermal performance and minimizing board area usage in integrated bus functions. Multiple functions released in the 56-ball MicroStar Jr.E package have superior performance characteristics compa - Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Серия: SN74AVC16T245-Q1 (1)
- Semiconductors> Logic> Voltage Level Translation> Direction Controlled Voltage Translation
