Datasheet Texas Instruments SN74GTL2007 — Даташит
Серия | SN74GTL2007 |
12-Bit GTL-/GTL/GTL+ to LVTTL Translator
Купить SN74GTL2007 на РадиоЛоцман.Цены — от 23 до 232 ₽ 23 предложений от 18 поставщиков Трансляция - уровни напряжения 12-Bit GTL-/GTL/GTL+ to LVTTL Translator | |||
SN74GTL2007PWRG4 Texas Instruments | от 23 ₽ | ||
SN74GTL2007PWR Texas Instruments | 70 ₽ | ||
SN74GTL2007PWR Texas Instruments | 101 ₽ | ||
SN74GTL2007PWR Texas Instruments | 231 ₽ |
SN74GTL2007PW | SN74GTL2007PWR | |
Статус продукта | В производстве | В производстве |
Доступность образцов у производителя | Да | Нет |
N | 1 | 2 |
Pin | 28 | 28 |
Package Type | PW | PW |
Industry STD Term | TSSOP | TSSOP |
Package QTY | 50 | 2000 |
Carrier | TUBE | LARGE T&R |
Маркировка | GK2007 | GK2007 |
Width (мм) | 4.4 | 4.4 |
Length (мм) | 9.7 | 9.7 |
Thickness (мм) | 1 | 1 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1.2 | 1.2 |
Parameters / Models | SN74GTL2007PW | SN74GTL2007PWR |
Bits | 12 | 12 |
F @ Nom Voltage(Max), Mhz | 100 | 100 |
ICC @ Nom Voltage(Max), мА | 12 | 12 |
Рабочий диапазон температур, C | от -40 до 85 | от -40 до 85 |
Output Drive (IOL/IOH)(Max), мА | 16 | 16 |
Package Group | TSSOP | TSSOP |
Package Size: mm2:W x L, PKG | 28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) | 28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) |
Rating | Catalog | Catalog |
Schmitt Trigger | No | No |
Technology Family | GTL | GTL |
VCC(Max), В | 3.6 | 3.6 |
VCC(Min), В | 3 | 3 |
Voltage(Nom), В | 3.3 | 3.3 |
tpd @ Nom Voltage(Max), нс | 10 | 10 |
- GTL/BTL: A Low-Swing Solution for High-Speed Digital Logic (Rev. A)PDF, 184 Кб, Версия: A, Файл опубликован: 1 мар 1997
GTL and BTL transceivers provide high-performance, excellent signal integrity and cost-effectiveness in high-speed backplane and point-to-point applications. This document discusses the GTL and BTL devices input/output (I/O) structure, power consumption, simultaneous switching, slew rate, and signal integrity. Design considerations for using these devices are provided. - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74GTL2007 (2)
- Semiconductors> Logic> Backplane Logic (GTL/TTL/BTL/ECL Transceiver/Translator)
