Datasheet Texas Instruments SN74LS112ADRE4 — Даташит
Серия | SN74LS112A |
Модель | SN74LS112ADRE4 |
Dual J-K Negative-Edge-Triggered Flip-Flops With Clear And Preset 16-SOIC 0 to 70
Dual J-K Negative-Edge-Triggered Flip-Flops With Preset And Clear datasheet
PDF, 1.3 Мб, Файл опубликован: 1 мар 1988
Купить SN74LS112ADRE4 на РадиоЛоцман.Цены — от 19 до 26 ₽ 13 предложений от 10 поставщиков Flip Flop 2 Element JK Type 1 Bit Negative Edge 16-SOIC (0.154, 3.90mm Width) | |||
SN74LS112ADRE4 Texas Instruments | 19 ₽ | ||
SN74LS112ADRE4 Texas Instruments | от 22 ₽ | ||
SN74LS112ADRE4 Texas Instruments | 24 ₽ | ||
SN74LS112ADRE4 Texas Instruments | по запросу |
Pin | 16 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | LS112A |
Width (мм) | 3.91 |
Length (мм) | 9.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Bits | 2 |
F @ Nom Voltage(Max) | 35 Mhz |
ICC @ Nom Voltage(Max) | 6 мА |
Output Drive (IOL/IOH)(Max) | -0.4/8 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 59 mm2: 6 x 9.9(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LS |
VCC(Max) | 5.25 В |
VCC(Min) | 4.75 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 20 нс |
- Designing with the SN54/74LS123 (Rev. A)PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
Серия: SN74LS112A (6)
- SN74LS112AD SN74LS112ADR SN74LS112ADRE4 SN74LS112AN SN74LS112AN3 SN74LS112ANSR
- Semiconductors > Logic > Flip-Flop/Latch/Register > J-K Flip-Flop
