Datasheet Texas Instruments SN74LS123NSR — Даташит
Серия | SN74LS123 |
Модель | SN74LS123NSR |
![Datasheet Texas Instruments SN74LS123NSR](http://www.ti.com/graphics/folders/partimages/SN74LS123.jpg)
Dual retriggerable monostable multivibrators 16-SO 0 to 70
Retriggerable Monostable Multivibrators datasheet
PDF, 1.4 Мб, Файл опубликован: 1 дек 1983
![]() 21 предложений от 14 поставщиков TEXAS INSTRUMENTS SN74LS123NSR Monostable Multivibrator, 74LS123, 23ns, 8mA, 4.75V to 5.25V, SOP-16 | |||
SN74LS123NSR Texas Instruments | 22 ₽ | ||
SN74LS123NSR Texas Instruments | 27 ₽ | ||
SN74LS123NSR Texas Instruments | от 76 ₽ | ||
SN74LS123NSR Texas Instruments | от 130 ₽ |
Pin | 16 |
Package Type | NS |
Industry STD Term | SOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | 74LS123 |
Width (мм) | 5.3 |
Length (мм) | 10.3 |
Thickness (мм) | 1.95 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
Bits | 2 |
F @ Nom Voltage(Max) | 35 Mhz |
ICC @ Nom Voltage(Max) | 20 мА |
Рабочий диапазон температур | от 0 до 70 C |
Output Drive (IOL/IOH)(Max) | 8/-0.4 мА |
Package Group | SO |
Package Size: mm2:W x L | 16SO: 80 mm2: 7.8 x 10.2(SO) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LS |
VCC(Max) | 5.25 В |
VCC(Min) | 4.75 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 56 нс |
- Designing with the SN74LVC1G123 Monostable MultivibratorPDF, 158 Кб, Файл опубликован: 14 июл 2015
- Designing with the SN54/74LS123 (Rev. A)PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
Серия: SN74LS123 (12)
- Semiconductors > Logic > Specialty Logic > Monostable Multivibrator
