Datasheet Texas Instruments SN74LVC16373DL — Даташит
Серия | SN74LVC16373 |
Модель | SN74LVC16373DL |
16-Bit Transparent D-Type Latch With 3-State Outputs 48-SSOP -40 to 85
16-Bit Transparent D-Type Latch With 3-State Outputs datasheet
PDF, 693 Кб, Версия: B, Файл опубликован: 1 июл 1995
Купить SN74LVC16373DL на РадиоЛоцман.Цены — от 44 до 231 ₽ 20 предложений от 13 поставщиков 16Bit Transparent D-Type Latch With 3-State Outputs 48-SSOP -40℃ to 85℃ | |||
SN74LVC16373DL Texas Instruments | 44 ₽ | ||
SN74LVC16373DL Texas Instruments | 46 ₽ | ||
SN74LVC16373DL Texas Instruments | 67 ₽ | ||
SN74LVC16373DL Texas Instruments | по запросу |
Pin | 48 |
Package Type | DL |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 25 |
Carrier | TUBE |
Маркировка | LVC16373 |
Width (мм) | 7.49 |
Length (мм) | 15.88 |
Thickness (мм) | 2.59 |
Pitch (мм) | .635 |
Max Height (мм) | 2.79 |
Mechanical Data | Скачать |
3-State Output | Yes |
Bits | 16 |
F @ Nom Voltage(Max) | 100 Mhz |
ICC @ Nom Voltage(Max) | 0.04 мА |
Output Drive (IOL/IOH)(Max) | 24/-24 мА |
Package Group | SSOP |
Package Size: mm2:W x L | 48SSOP: 164 mm2: 10.35 x 15.88(SSOP) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 2.7 В |
Voltage(Nom) | 2.7,3.3 В |
tpd @ Nom Voltage(Max) | 7,8 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC16373 (4)
- 74LVC16373DGGRE4 SN74LVC16373DGGR SN74LVC16373DL SN74LVC16373DLR
- Semiconductors > Logic > Flip-Flop/Latch/Register > D-Type Latch
