Datasheet Texas Instruments SN74LVTH322374 — Даташит
Серия | SN74LVTH322374 |
3.3-V ABT 32-Bit Edge-Triggered D-Type Flip-Flop with 3-State Outputs
SN74LVTH322374 datasheet
PDF, 704 Кб, Версия: C, Файл опубликован: 13 ноя 2006
Купить SN74LVTH322374 на РадиоЛоцман.Цены — от 72 до 220 ₽ 10 предложений от 10 поставщиков Flip Flop 4 Element D-Type 8 Bit Positive Edge 96-LFBGA | |||
SN74LVTH322374KR Texas Instruments | 72 ₽ | ||
SN74LVTH322374KR Texas Instruments | 171 ₽ | ||
SN74LVTH322374KR Texas Instruments | 219 ₽ | ||
SN74LVTH322374KR Texas Instruments | 220 ₽ |
74LVTH322374ZKER | |
Статус продукта | В производстве |
N | 1 |
Pin | 96 |
Package Type | ZKE |
Industry STD Term | BGA MICROSTAR |
JEDEC Code | R-PBGA-N |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | HW374 |
Width (мм) | 5.5 |
Length (мм) | 13.5 |
Thickness (мм) | .85 |
Pitch (мм) | .8 |
Max Height (мм) | 1.4 |
Mechanical Data | Скачать |
Parameters / Models | 74LVTH322374ZKER |
3-State Output | Yes |
Bits | 32 |
F @ Nom Voltage(Max), Mhz | 160 |
ICC @ Nom Voltage(Max), мА | 10 |
Рабочий диапазон температур, C | от -40 до 85 |
Output Drive (IOL/IOH)(Max), мА | 12/-12 |
Package Group | LFBGA |
Package Size: mm2:W x L, PKG | 96LFBGA: 74 mm2: 5.5 x 13.5(LFBGA) |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVT |
VCC(Max), В | 3.6 |
VCC(Min), В | 2.7 |
Voltage(Nom), В | 3.3 |
tpd @ Nom Voltage(Max), нс | 5.3 |
- LVT Family Characteristics (Rev. A)PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti - LVT-to-LVTH ConversionPDF, 84 Кб, Файл опубликован: 8 дек 1998
Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed. - Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of - 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
TI?s 56-ball MicroStar Jr.E package registered under JEDEC MO-225 has demonstrated through modeling and experimentation that it is an optimal solution for reducing inductance and capacitance improving thermal performance and minimizing board area usage in integrated bus functions. Multiple functions released in the 56-ball MicroStar Jr.E package have superior performance characteristics compa - Bus-Interface Devices With Output-Damping Resistors Or Reduced-Drive Outputs (Rev. A)PDF, 105 Кб, Версия: A, Файл опубликован: 1 авг 1997
The spectrum of bus-interface devices with damping resistors or balanced/light output drive currently offered by various logic vendors is confusing at best. Inconsistencies in naming conventions and methods used for implementation make it difficult to identify the best solution for a given application. This report attempts to clarify the issue by looking at several vendors? approaches and discussi - Understanding Advanced Bus-Interface Products Design GuidePDF, 253 Кб, Файл опубликован: 1 май 1996
- Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Many telecom and networking applications require that cards be inserted and extracted from a live backplane without interrupting data or damaging components. To achieve this interface terminals of the card must be electrically isolated from the bus system during insertion or extraction from the backplane. To facilitate this Texas Instruments provides bus-interface and logic devices with features - Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Power-Up Behavior of Clocked Devices (Rev. A)PDF, 34 Кб, Версия: A, Файл опубликован: 6 фев 2015
Серия: SN74LVTH322374 (1)
- Semiconductors> Logic> Flip-Flop/Latch/Register> D-Type Flip-Flop
