Datasheet Texas Instruments SN888C — Даташит
Серия | SN888C |
Bus-Polarity Correcting RS-485 Transceiver with IEC-ESD Protection
SN888C Bus-Polarity Correcting RS-485 Transceiver for E-Meters datasheet
PDF, 967 Кб, Файл опубликован: 25 сен 2013
Купить SN888CD на РадиоЛоцман.Цены — от 84 до 9 194 ₽ 8 предложений от 7 поставщиков Микросхема: IC TRANSCEIVER HALF 1/1 8SOIC | |||
SN888CD Texas Instruments | 84 ₽ | ||
SN888CD Texas Instruments | 86 ₽ | ||
SN888CD Texas Instruments | от 303 ₽ | ||
SN888CD | 9 194 ₽ |
SN888CD | SN888CDR | |
N | 1 | 2 |
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 75 | 2500 |
Carrier | TUBE | LARGE T&R |
Маркировка | EESA | RS485N |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Parameters / Models | SN888CD | SN888CDR |
Common Mode Range | -7 to 12 | -7 to 12 |
Duplex | Half | Half |
Fail Safe | None | None |
Fault Protection, В | -18 to 18 | -18 to 18 |
HBM ESD, kV | 16 | 16 |
ICC(Max), мА | 0.9 | 0.9 |
IEC 61000-4-2 Contact, +/- kV | 12 | 12 |
Isolated | No | No |
No. of RX | 1 | 1 |
No. of TX | 1 | 1 |
Number of Nodes | 256 | 256 |
Рабочий диапазон температур, C | от -40 до 85 | от -40 до 85 |
Package Group | SOIC | SOIC |
Rating | Catalog | Catalog |
Signaling Rate(Max), Mbps | 0.25 | 0.25 |
Supply Voltage(s)(Nom), В | 5 | 5 |
- Semiconductors> Interface> RS-485 Transceivers
