Datasheet Texas Instruments TAS5411-Q1 — Даташит
Серия | TAS5411-Q1 |
8-W Analog Input Mono Automotive Class-D Audio Amplifier With Load Dump, I2C Diagnostics​​
TAS5411-Q1 8-W Mono Automotive Class-D Audio Amplifier With Load Dump and I2C Diagnostics datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 9 дек 2015
Купить TAS5411-Q1 на РадиоЛоцман.Цены — от 14 837 до 48 182 ₽ 6 предложений от 6 поставщиков Audio IC Development Tools TAS5411-Q1 EVM 1CH Analog Input Class-D Audio Amplifier w/I2C Diagnostics & Protection for Auto | |||
TAS5411Q1EVM Texas Instruments | 14 837 ₽ | ||
TAS5411Q1EVM Texas Instruments | 15 748 ₽ | ||
TAS5411Q1EVM Texas Instruments | 15 819 ₽ | ||
TAS5411Q1EVM Texas Instruments | 48 182 ₽ |
TAS5411QPWPRQ1 | |
Статус продукта | В производстве |
TAS5411QPWPRQ1 | |
N | 1 |
Pin | 16 |
Package Type | PWP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | TAS5411 |
Width (мм) | 4.4 |
Length (мм) | 5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Parameters / Models | TAS5411QPWPRQ1 |
Analog Supply (V), Max | 4.5 |
Closed/Open Loop | Closed |
Control Interface | I2C |
Рабочий диапазон температур, C | от -40 до 125 |
Package Group | HTSSOP |
Package Size: mm2:W x L, PKG | 16HTSSOP: 22 mm2: 4.4 x 5(HTSSOP) |
Power Stage Supply(Max), В | 18 |
Power Stage Supply(Min), В | 4.5 |
Power to Bridge Tied Load(Max), W | 8 |
Rating | Automotive |
Speaker Channels, Max | 1 |
Supported Bridge Tied Load(Min), Ohms | 2 |
TAS5411QPWPRQ1 | |
- Short-to-Battery Protection Strategies for Class-D AmplifiersPDF, 3.2 Мб, Файл опубликован: 11 ноя 2016
This document introduces the potential faults that can occur in class-D amplifier solutions, and describes how most faults are intrinsically protected for and how to extend coverage to protect against all short-circuit faults. Of particular focus is the case when an output is shorted to a battery voltage higher than the device supply voltage. This fault allows the parasitic body diode found in the - Class-D LC Filter Design (Rev. B)PDF, 488 Кб, Версия: B, Файл опубликован: 20 фев 2015
- AN-1737 Managing EMI in Class D Audio Applications (Rev. A)PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit. - Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5411-Q1 (1)
- Semiconductors> Audio> Mid-Power Audio Amplifiers (5-50W)> Analog Input Amplifiers
