Datasheet Texas Instruments TAS5412-Q1 — Даташит
Серия | TAS5412-Q1 |
Two-Channel Automotive Digital Amplifier
TAS5412-Q1 Automotive Digital Amplifier datasheet
PDF, 1.9 Мб, Версия: A, Файл опубликован: 15 окт 2013
Купить TAS5412-Q1 на РадиоЛоцман.Цены — от 10 987 до 103 959 ₽ 5 предложений от 5 поставщиков EVAL MODULE FOR TAS5412Q1PHD | |||
TAS5412Q1PHDEVM Texas Instruments | 10 987 ₽ | ||
TAS5412Q1PHDEVM Texas Instruments | 24 227 ₽ | ||
TAS5412Q1PHDEVM Texas Instruments | 96 760 ₽ | ||
TAS5412Q1PHDEVM Texas Instruments | 103 959 ₽ |
TAS5412TPHDRQ1 | |
Статус продукта | В производстве |
TAS5412TPHDRQ1 | |
N | 1 |
Pin | 64 |
Package Type | PHD |
Industry STD Term | HTQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | TAS5412TQ1 |
Width (мм) | 14 |
Length (мм) | 14 |
Thickness (мм) | 1 |
Pitch (мм) | .8 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Parameters / Models | TAS5412TPHDRQ1 |
Audio Input Type | Analog |
Control Interface | I2C |
Рабочий диапазон температур, C | от -40 до 105 |
Выходная мощность, W | 25 |
Power Stage Supply(Max), В | 24 |
Power Stage Supply(Min), В | 6 |
Power to Bridge Tied Load(Max), W | 70 |
Power to Parallel Bridge Tied Load(Max), W | 116 |
Speaker Channels, Max | 2 |
THD + N @ 1 kHz, % | 0.02 |
TAS5412TPHDRQ1 | |
- AN-1737 Managing EMI in Class D Audio Applications (Rev. A)PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit. - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs. - Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5412-Q1 (1)
- Semiconductors> Audio> High-Power Audio Amplifiers (>50W)> Analog Input Class-D
