Datasheet Texas Instruments TAS5414C-Q1 — Даташит
Серия | TAS5414C-Q1 |
28-W Automotive Analog Single-Ended Input 4-Channel Class-D Amp with Load Dump Protection
TAS54x4C-Q1 Four-Channel Automotive Digital Amplifiers datasheet
PDF, 2.3 Мб, Версия: E, Файл опубликован: 23 янв 2015
Купить TAS5414C-Q1 на РадиоЛоцман.Цены — от 10 980 до 67 750 ₽ 5 предложений от 5 поставщиков EVALUATION BOARD FOR TAS5414 | |||
TAS5414CQ1PHDEVM Texas Instruments | 10 980 ₽ | ||
TAS5414CQ1PHDEVM Texas Instruments | 13 988 ₽ | ||
TAS5414CQ1PHDEVM Texas Instruments | 14 013 ₽ | ||
TAS5414CQ1PHDEVM Texas Instruments | 67 750 ₽ |
TAS5414CTPHDRQ1 | |
Статус продукта | В производстве |
TAS5414CTPHDRQ1 | |
N | 1 |
Pin | 64 |
Package Type | PHD |
Industry STD Term | HTQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | TAS5414CTQ1 |
Width (мм) | 14 |
Length (мм) | 14 |
Thickness (мм) | 1 |
Pitch (мм) | .8 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Parameters / Models | TAS5414CTPHDRQ1 |
Audio Input Type | Analog |
Control Interface | I2C |
Рабочий диапазон температур, C | от -40 до 105 |
Выходная мощность, W | 25 |
Power Stage Supply(Max), В | 24 |
Power Stage Supply(Min), В | 6 |
Power to Bridge Tied Load(Max), W | 70 |
Power to Parallel Bridge Tied Load(Max), W | 116 |
Speaker Channels, Max | 4 |
THD + N @ 1 kHz, % | 0.02 |
TAS5414CTPHDRQ1 | |
- AN-1737 Managing EMI in Class D Audio Applications (Rev. A)PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit. - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs. - Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5414C-Q1 (1)
- Semiconductors> Audio> High-Power Audio Amplifiers (>50W)> Analog Input Class-D
