Datasheet Texas Instruments TAS5424C-Q1 — Даташит
Серия | TAS5424C-Q1 |
4-Channel Automotive Digital Amplifiers with differential input delivering 28W/Ch into 4Ohm
TAS54x4C-Q1 Four-Channel Automotive Digital Amplifiers datasheet
PDF, 2.3 Мб, Версия: E, Файл опубликован: 23 янв 2015
Купить TAS5424C-Q1 на РадиоЛоцман.Цены — от 10 987 до 89 295 ₽ EVAL MODULE FOR TAS5424CQ1DKE | |||
TAS5424CQ1DKEEVM Texas Instruments | 10 987 ₽ | ||
TAS5424CQ1DKEEVM Texas Instruments | 17 664 ₽ | ||
TAS5424CQ1DKEEVM Texas Instruments | 17 729 ₽ | ||
TAS5424CQ1DKEEVM Texas Instruments | 89 295 ₽ |
TAS5424CTDKDRQ1 | TAS5424CTDKERQ1 | |
Статус продукта | Анонсирован | В производстве |
Доступность образцов у производителя | Нет | Да |
N | 1 | 2 |
Pin | 44 | 44 |
Package Type | DKD | DKE |
Industry STD Term | HSSOP | HSSOP |
Width (мм) | 11 | 11 |
Length (мм) | 15.9 | 15.9 |
Thickness (мм) | 3.5 | 3.5 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 3.6 | 3.6 |
Package QTY | 500 | |
Carrier | LARGE T&R | |
Маркировка | TAS5424CQ1 |
Parameters / Models | TAS5424CTDKDRQ1 | TAS5424CTDKERQ1 |
Analog Supply (V)(Max) | 24 | |
Analog Supply (V)(Min) | 6 | |
Approx. Price (US$) | 7.95 | 1ku | |
Audio Input Type | Analog | Analog |
Closed/Open Loop | Closed | |
Control Interface | I2C | I2C |
Iq(Max)(mA) | 20 | |
Рабочий диапазон температур, C | от -40 до 105 | |
Operating Temperature Range(C) | -40 to 105 | |
Выходная мощность, W | 45 | |
Output Power(W) | 45 | |
Package Group | HSSOP | |
Package Size: mm2:W x L (PKG) | 44HSSOP: 175 mm2: 11 x 15.9(HSSOP) | |
Power Stage Supply(Max), В | 24 | |
Power Stage Supply(Max)(V) | 24 | |
Power Stage Supply(Min), В | 6 | |
Power Stage Supply(Min)(V) | 6 | |
Power to Bridge Tied Load(Max), W | 70 | |
Power to Bridge Tied Load(Max)(W) | 70 | |
Power to Parallel Bridge Tied Load(Max), W | 116 | |
Power to Parallel Bridge Tied Load(Max)(W) | 116 | |
Rating | Automotive | |
Speaker Channels, Max | 4 | |
Speaker Channels(Max) | 4 | |
Supported Bridge Tied Load(Min)(Ohms) | 2 | |
Supported Parallel Bridge Tied Load(Min)(Ohms) | 1 | |
THD + N @ 1 kHz, % | 0.02 | |
THD + N @ 1 kHz(%) | 0.02 |
RoHS | Не совместим | Совместим |
- AN-1737 Managing EMI in Class D Audio Applications (Rev. A)PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit. - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs. - Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5424C-Q1 (2)
- Semiconductors> Audio> High-Power Audio Amplifiers (>50W)> Analog Input Class-D
