Altinkaya: турецкие корпуса для РЭА
Datasheet Texas Instruments TAS5622A — Даташит
СерияTAS5622A
125 W Stereo/250W Mono PurePath HD Digital-Input Power Stage
TAS5622A 125-W Stereo and 250-W Stereo PurePathв„ў HD Digital-Input Class-D Power Stage datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 31 мар 2015
Acme Chip
TAS5622A
TAS5622ADDVTAS5622ADDVR
Доступность образцов у производителяНетДа
N12
Pin4444
Package TypeDDVDDV
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY352000
CarrierTUBELARGE T&R
МаркировкаTAS5622ATAS5622A
Width (мм)6.16.1
Length (мм)1414
Thickness (мм)1.151.15
Pitch (мм).635.635
Max Height (мм)1.21.2
Parameters / ModelsTAS5622ADDV
TAS5622ADDV
TAS5622ADDVR
TAS5622ADDVR
Audio Input TypePWMPWM
Control InterfaceHardwareHardware
Рабочий диапазон температур, Cот -40 до 125от -40 до 125
Выходная мощность, W125125
Power Stage Supply(Max), В3434
Power Stage Supply(Min), В1212
Power to Bridge Tied Load(Max), W150150
Power to Parallel Bridge Tied Load(Max), W300300
SNR, дБ105105
Speaker Channels, Max44
THD + N @ 1 kHz, %0.0250.025
RoHSСовместимСовместим
  • Power Rating in Audio Amplifier (Rev. A)
    PDF, 514 Кб, Версия: A, Файл опубликован: 4 мар 2005
    Average consumers often weigh heavily on cost versus power rating of audio amplifiers as their basis for purchasing one. Depending on the marketing strategy, the powerrating methodology for audio amplifiers can vary from manufacturer to manufacturer.The purpose of this document is to clarify three commonly used power ratings: average power, peak power, and PMPO.The following Texas Instru
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5622A (2)
  • Semiconductors> Audio> High-Power Audio Amplifiers (>50W)> PWM Input Class-D
На английском языке: Datasheet Texas Instruments TAS5622A
