Datasheet Texas Instruments TAS5706B — Даташит
СерияTAS5706B
20W Closed-loop I2S Audio Power Amplifier with Speaker EQ, DRC and SE output support
20W stereo Digital Audio Power Amplifier With EQ and DRC. datasheet
PDF, 1.9 Мб, Версия: D, Файл опубликован: 10 сен 2009
20W Closed-loop I2S Audio Power Amplifier with Speaker EQ DRC and SE output support
T-electron
TAS5706B
Akcel
TAS5706B
Acme Chip
TAS5706B
TAS5706BPAPTAS5706BPAPR
Доступность образцов у производителяДаНет
N12
Pin6464
Package TypePAPPAP
Industry STD TermHTQFPHTQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY1601000
CarrierJEDEC TRAY (5+1)LARGE T&R
МаркировкаTAS5706BTAS5706B
Width (мм)1010
Length (мм)1010
Thickness (мм)11
Pitch (мм).5.5
Max Height (мм)1.21.2
Parameters / ModelsTAS5706BPAP
TAS5706BPAP
TAS5706BPAPR
TAS5706BPAPR
Analog Supply (V), Max33
Audio Input TypeDigitalDigital
Closed/Open LoopClosedClosed
Control InterfaceHardware,SoftwareHardware,Software
Рабочий диапазон температур, Cот 0 до 85от 0 до 85
Package GroupHTQFPHTQFP
Package Size: mm2:W x L, PKG64HTQFP: 144 mm2: 12 x 12(HTQFP)64HTQFP: 144 mm2: 12 x 12(HTQFP)
Power Stage Supply(Max), В2626
Power Stage Supply(Min), В1010
Power to Bridge Tied Load(Max), W2020
RatingCatalogCatalog
Sampling Rate(Max), kHz192192
Sampling Rate(Min), kHz3232
Speaker Channels, Max44
Supported Bridge Tied Load(Min), Ohms88
RoHSСовместимСовместим
  • TAS57xx Dynamic Range Control
    PDF, 324 Кб, Файл опубликован: 18 июн 2010
    This application report provides background information, general equations, and instructions for proper use of the Texas Instruments TAS57xx series Dynamic Range Control (DRC). Topics include I2C configuration, single-band and dual-band DRC, coefficient computation, device offerings, and user interface configuration.
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5706B (2)
  • Semiconductors> Audio> Mid-Power Audio Amplifiers (5-50W)> Digital I2S Input Class-D
На английском языке: Datasheet Texas Instruments TAS5706B
