Datasheet Texas Instruments TAS5731M — Даташит
Серия | TAS5731M |
30-W Stereo Digital Audio Power Amplifier with DSP and 2.1 Mode
TAS5731M 2 Г— 30-W Digital Audio Power Amplifier With DSP and 2.1 Mode datasheet
PDF, 2.3 Мб, Версия: C, Файл опубликован: 31 авг 2015
TAS5731M TQFP48,7x7mm Texas Instruments | 765 ₽ | ||
TAS5731M Texas Instruments | по запросу |
TAS5731MPHP | TAS5731MPHPR | |
Статус продукта | В производстве | В производстве |
Доступность образцов у производителя | Нет | Да |
N | 1 | 2 |
Pin | 48 | 48 |
Package Type | PHP | PHP |
Industry STD Term | HTQFP | HTQFP |
JEDEC Code | S-PQFP-G | S-PQFP-G |
Package QTY | 250 | 1000 |
Carrier | JEDEC TRAY (5+1) | LARGE T&R |
Маркировка | TAS5731M | TAS5731M |
Width (мм) | 7 | 7 |
Length (мм) | 7 | 7 |
Thickness (мм) | 1 | 1 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | 1.2 | 1.2 |
Parameters / Models | TAS5731MPHP | TAS5731MPHPR |
Analog Supply (V), Max | 3 | 3 |
Audio Input Type | Digital | Digital |
Closed/Open Loop | Open | Open |
Control Interface | Software | Software |
Рабочий диапазон температур, C | от -40 до 85 | от -40 до 85 |
Package Group | HTQFP | HTQFP |
Package Size: mm2:W x L, PKG | 48HTQFP: 81 mm2: 9 x 9(HTQFP) | 48HTQFP: 81 mm2: 9 x 9(HTQFP) |
Power Stage Supply(Max), В | 26.4 | 26.4 |
Power Stage Supply(Min), В | 8 | 8 |
Power to Bridge Tied Load(Max), W | 37 | 37 |
Power to Parallel Bridge Tied Load(Max), W | 70 | 70 |
Rating | Catalog | Catalog |
Sampling Rate(Max), kHz | 48 | 48 |
Sampling Rate(Min), kHz | 4 | 4 |
Speaker Channels, Max | 2 | 2 |
Supported Bridge Tied Load(Min), Ohms | 4 | 4 |
- TAS57xx Dynamic Range ControlPDF, 324 Кб, Файл опубликован: 18 июн 2010
This application report provides background information, general equations, and instructions for proper use of the Texas Instruments TAS57xx series Dynamic Range Control (DRC). Topics include I2C configuration, single-band and dual-band DRC, coefficient computation, device offerings, and user interface configuration. - AN-1737 Managing EMI in Class D Audio Applications (Rev. A)PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit. - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs. - Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TAS5731M (2)
- Semiconductors> Audio> Mid-Power Audio Amplifiers (5-50W)> Digital I2S Input Class-D
