Datasheet Texas Instruments TCA7408 — Даташит
Серия | TCA7408 |
Low-voltage 8-bit I2C I/O Expander with Interrupt Output Reset I/O Direction Registers
TCA7408 Low-Voltage 8-Bit I2C and SMBus I/O Expander With Interrupt Output, RESET Input, I/O Direction Registers, and Programmable Pull-Up/Pull-Down datasheet
PDF, 1.0 Мб, Версия: C, Файл опубликован: 29 июн 2015
Купить TCA7408 на РадиоЛоцман.Цены — от 54 до 6 492 ₽ 16 предложений от 13 поставщиков TEXAS INSTRUMENTS TCA7408ZSZRI/O EXPANDER, 8 BIT, 400KHZ, UCSP-16 | |||
TCA7408ZSZR Texas Instruments | от 54 ₽ | ||
TCA7408ZSZR Texas Instruments | 63 ₽ | ||
TCA7408ZSZR Texas Instruments | 119 ₽ | ||
TCA7408ZSZR | по запросу |
TCA7408ZSZR | |
Статус продукта | В производстве |
TCA7408ZSZR | |
N | 1 |
Pin | 16 |
Package Type | ZSZ |
Industry STD Term | uCSP |
JEDEC Code | S-PLGA-N |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | ZUQ |
Width (мм) | 2 |
Length (мм) | 2 |
Thickness (мм) | .435 |
Pitch (мм) | .5 |
Max Height (мм) | .55 |
Mechanical Data | Скачать |
Parameters / Models | TCA7408ZSZR |
I2C Address | 0100 00x |
Max Frequency, kHz | 400 |
Number of I/Os | 8 |
Рабочий диапазон температур, C | от -40 до 85 |
Package Group | uCSP |
Rating | Catalog |
VCC(Max), В | 5.5 |
VCC(Min), В | 1.65 |
Voltage Nodes, В | 1.8,2.7,3.3,3.6,5 |
fSCLK(Max), МГц | 0.4 |
TCA7408ZSZR | |
- Choosing the Correct I2C Device for New DesignsPDF, 87 Кб, Файл опубликован: 7 сен 2016
The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h - Maximum Clock Frequency of I2C Bus Using RepeatersPDF, 116 Кб, Файл опубликован: 15 май 2015
TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters - I2C Bus Pull-Up Resistor CalculationPDF, 157 Кб, Файл опубликован: 13 фев 2015
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: TCA7408 (1)
- Semiconductors> Interface> I2C> I2C IO Expander
