Datasheet Texas Instruments TCA9800DGKT — Даташит
Серия | TCA9800 |
Модель | TCA9800DGKT |
I2C Level-Translation I2C Bus Repeater 8-VSSOP -40 to 85
TCA9800 Level-Translating I2C Bus Buffer/Repeater datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 14 мар 2017
Купить TCA9800DGKT на РадиоЛоцман.Цены — от 63 до 281 ₽ 16 предложений от 9 поставщиков Voltage Level Translator Bidirectional 1 Circuit 2 Channel 8-VSSOP | |||
TCA9800DGKT Texas Instruments | 63 ₽ | ||
TCA9800DGKT Texas Instruments | 66 ₽ | ||
TCA9800DGKT Texas Instruments | 68 ₽ | ||
TCA9800DGKT Texas Instruments | 133 ₽ |
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | 15B |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Channel Width | 2 |
Master Side I2C Bus Capacitance Supported | 400 пФ |
Max Frequency | 400 kHz |
Количество выходов | 2 |
Package Group | VSSOP |
Slave Side I2C Bus Capacitance Supported | 400 пФ |
Special Features | Enable Pin,Low Voltage,Open-Drain I/O Type,Power Save Mode |
VCC(Max) | 3.6 В |
VCC(Min) | 0.8 В |
fSCLK(Max) | 0.4 МГц |
- Evaluation Modules & Boards: TCA9802EVM
TCA980x Family of IВІC and SMBus Level Shifters Evaluation Module
- Advantages and Design Considerations of the TCA980x FamilyPDF, 168 Кб, Файл опубликован: 30 мар 2017
- Choosing the Correct I2C Device for New DesignsPDF, 87 Кб, Файл опубликован: 7 сен 2016
The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h - Maximum Clock Frequency of I2C Bus Using RepeatersPDF, 116 Кб, Файл опубликован: 15 май 2015
TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters - I2C Bus Pull-Up Resistor CalculationPDF, 157 Кб, Файл опубликован: 13 фев 2015
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: TCA9800 (2)
- TCA9800DGKR TCA9800DGKT
- Semiconductors > Interface > I2C > I2C Level Shifters, Buffers, and Hubs
