Datasheet Texas Instruments TCA9800 — Даташит
Серия | TCA9800 |
I2C Level-Translation I2C Bus Repeater
TCA9800 Level-Translating I2C Bus Buffer/Repeater datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 14 мар 2017
Купить TCA9800 на РадиоЛоцман.Цены — от 34 до 81 ₽ 16 предложений от 9 поставщиков Voltage Level Translator Bidirectional 1 Circuit 2 Channel 8-VSSOP | |||
TCA9800DGKR Texas Instruments | 34 ₽ | ||
TCA9800DGKR Texas Instruments | 35 ₽ | ||
TCA9800DGKR Texas Instruments | 36 ₽ | ||
TCA9800DGKR Texas Instruments | от 81 ₽ |
TCA9800DGKR | TCA9800DGKT | |
Статус продукта | В производстве | В производстве |
Доступность образцов у производителя | Да | Нет |
N | 1 | 2 |
Pin | 8 | 8 |
Package Type | DGK | DGK |
Industry STD Term | VSSOP | VSSOP |
Package QTY | 2500 | 250 |
Carrier | LARGE T&R | SMALL T&R |
Маркировка | 15B | 15B |
Width (мм) | 3 | 3 |
Length (мм) | 3 | 3 |
Thickness (мм) | .97 | .97 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1.07 | 1.07 |
Parameters / Models | TCA9800DGKR | TCA9800DGKT |
Channel Width | 2 | 2 |
Master Side I2C Bus Capacitance Supported, пФ | 400 | 400 |
Max Frequency, kHz | 400 | 400 |
Количество выходов | 2 | 2 |
Рабочий диапазон температур, C | от -40 до 85 | от -40 до 85 |
Package Group | VSSOP | VSSOP |
Slave Side I2C Bus Capacitance Supported, пФ | 400 | 400 |
Special Features | Enable Pin,Low Voltage,Open-Drain I/O Type,Power Save Mode | Enable Pin,Low Voltage,Open-Drain I/O Type,Power Save Mode |
VCC(Max), В | 3.6 | 3.6 |
VCC(Min), В | 0.8 | 0.8 |
fSCLK(Max), МГц | 0.4 | 0.4 |
- Choosing the Correct I2C Device for New DesignsPDF, 87 Кб, Файл опубликован: 7 сен 2016
The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h - Maximum Clock Frequency of I2C Bus Using RepeatersPDF, 116 Кб, Файл опубликован: 15 май 2015
TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters - I2C Bus Pull-Up Resistor CalculationPDF, 157 Кб, Файл опубликован: 13 фев 2015
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: TCA9800 (2)
- Semiconductors> Interface> I2C> I2C Hub, Buffer, Repeater
