Datasheet Texas Instruments THS4541-Q1 — Даташит
Серия | THS4541-Q1 |
Automotive High-Speed Differential I/O Amplifier
THS4541-Q1 Negative Rail Input, Rail-to-Rail Output, Precision, 850-MHz Fully Differential Amplifier datasheet
PDF, 2.1 Мб, Версия: A, Файл опубликован: 19 ноя 2015
THS4541-Q1 Texas Instruments | по запросу |
THS4541QRGTRQ1 | |
Статус продукта | В производстве |
THS4541QRGTRQ1 | |
N | 1 |
Pin | 16 |
Package Type | RGT |
Industry STD Term | VQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | 4541Q1 |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Parameters / Models | THS4541QRGTRQ1 |
2nd Harmonic, dBc | 95 |
3rd Harmonic, dBc | 90 |
@ MHz | 10 |
Acl, min spec gain, V/V | 1 |
Additional Features | Shutdown |
Архитектура | Fully Differential |
BW @ Acl, МГц | 620 |
CMRR(Min), дБ | 85 |
CMRR(Typ), дБ | 100 |
GBW(Typ), МГц | 850 |
Input Bias Current(Max), pA | 13000000 |
Iq per channel(Max), мА | 10.5 |
Iq per channel(Typ), мА | 10.1 |
Количество каналов | 1 |
Offset Drift(Typ), uV/C | 2.4 |
Рабочий диапазон температур, C | от -40 до 125 |
Output Current(Typ), мА | 100 |
Package Group | VQFN |
Package Size: mm2:W x L, PKG | 16VQFN: 9 mm2: 3 x 3(VQFN) |
Rail-to-Rail | In to V-,Out |
Rating | Automotive |
Slew Rate(Typ), V/us | 1500 |
Total Supply Voltage(Max), +5V=5, +/-5V=10 | 5.4 |
Total Supply Voltage(Min), +5V=5, +/-5V=10 | 2.7 |
Vn at 1kHz(Typ), нВ/rtГц | 32 |
Vn at Flatband(Typ), нВ/rtГц | 2.2 |
Vos (Offset Voltage @ 25C)(Max), мВ | 0.45 |
THS4541QRGTRQ1 | |
- Design for a Wideband Differential Transimpedance DAC Output (Rev. A)PDF, 438 Кб, Версия: A, Файл опубликован: 17 окт 2016
High-speed digital-to-analog converters commonly offer a complementary current output signal. Most output interface implementations use either a resistive load and/or a transformer to convert this current source signal to a voltage. Where a dc-coupled interface is required, a carefully designed differential transimpedance stage can offer an attractive alternative. Design considerations and options - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: THS4541-Q1 (1)
- Semiconductors> Amplifiers> Operational Amplifiers (Op Amps)> High-Speed Op Amps (>=50MHz)
