Datasheet Texas Instruments THS8200 — Даташит
Серия | THS8200 |
Triple 10-Bit All Format Video DAC
THS8200 All-Format Oversampled Component Video/PC Graphics D/A System With Three 11-Bit DACs, CGMS Data Insertion datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 18 сен 2014
Купить THS8200 на РадиоЛоцман.Цены — от 75 до 1 339 ₽ 25 предложений от 18 поставщиков TEXAS INSTRUMENTS THS8200PFP Digital to Analog Converter, 11Bit, 205MSPS, Serial, 3V to 3.6V, HTQFP, 80Pins | |||
THS8200PFPG4 Texas Instruments | 75 ₽ | ||
THS8200PFP Texas Instruments | от 142 ₽ | ||
THS8200,TI Texas Instruments | по запросу | ||
THS8200PGP Texas Instruments | по запросу |
THS8200PFP | |
Статус продукта | Не рекомендуется для новых разработок |
THS8200PFP | |
N | 1 |
Pin | 80 |
Package Type | PFP |
Industry STD Term | HTQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 96 |
Carrier | JEDEC TRAY (10+1) |
Маркировка | THS8200 |
Width (мм) | 12 |
Length (мм) | 12 |
Thickness (мм) | 1 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
THS8200PFP | |
- THS8200 PCB Layout GuidelinesPDF, 40 Кб, Файл опубликован: 16 июн 2010
- Analog Reconstruction Filter for HDTV Using THS8133, THS8134, THS8135, THS8200PDF, 58 Кб, Файл опубликован: 14 сен 2001
The THS8133, THS8134, THS8135, and the THS8200 devices are part of a family of chips for graphics and video applications, which contain triple DACs that operate from 80 MSPS to 240 MSPS. For television applications, an analog low-pass filter is required to reconstruct the signal that is input to the monitor. High definition television (HDTV) requires a sampling frequency of 74.25 MHz and has pass- - High Resolution Video Using the DM642 DSP and the THS8200 Driver (Rev. A)PDF, 440 Кб, Версия: A, Файл опубликован: 3 май 2004
The DM642 DSP has three 20-bit video ports capable of high definition (HD) display. The video ports can be programmed to follow HDTV standards, such as SMPTE274M and SMPTE296M. These HDTV standards follow a 4:2:2 convention where luminance and chrominance signals are separated onto two different 8- or 10-bit data paths. This convention is more commonly called Y/C mode. Many new HD displays accept - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: THS8200 (1)
- Semiconductors> Video and Imaging> Video DACs
