Datasheet Texas Instruments V62/10610-01YE — Даташит
Серия | TLC5940-EP |
Модель | V62/10610-01YE |
Enhanced Product 16 Channel LED Driver With DOT Correction and Grayscale PWM Control 32-VQFN -40 to 125
TLC5940-EP 16-Channel LED Driver With Dot Correction and Grayscale PWM Control datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 23 сен 2016
Купить V62/10610-01YE на РадиоЛоцман.Цены — от 251 до 256 ₽ 6 предложений от 6 поставщиков Драйверы систем светодиодного освещения EP 16Ch LED Drvr | |||
V62/10610-01YE Texas Instruments | 251 ₽ | ||
V62/10610-01YE Texas Instruments | 256 ₽ | ||
V62/10610-01YE | по запросу | ||
V62/10610-01YE Texas Instruments | по запросу |
Pin | 32 | 32 |
Package Type | RHB | RHB |
Industry STD Term | VQFN | VQFN |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 3000 | 3000 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | 5940EP | TLC |
Width (мм) | 5 | 5 |
Length (мм) | 5 | 5 |
Thickness (мм) | .9 | .9 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | 1 | 1 |
Data Vin(Max) | 5.5 В |
Data Vin(Min) | 3 В |
Package Group | VQFN |
Package Size: mm2:W x L | 32VQFN: 25 mm2: 5 x 5(VQFN) PKG |
Rating | HiRel Enhanced Product |
- TLC5940 One Wire Control--Eliminating Microprocessor Control for Integr LED DrivPDF, 410 Кб, Файл опубликован: 25 сен 2006
LED drivers such as the TLC5940 provide many integrated features that require a microprocessor interface to use. When these features are not needed, the TLC5940 can be configured with a single-wire interface for simple on/off control. This provides a low-cost solution to drive multiple LEDs with tight current matching while still allowing for PWM dimming in applications such as backlighting or gen - TLC5940 PWM dimming provides superior color quality in LED video displaysPDF, 215 Кб, Файл опубликован: 18 апр 2006
- Grayscale and Dot-Corrected LED Display Using TLC5941 (Rev. A)PDF, 198 Кб, Версия: A, Файл опубликован: 5 мар 2008
The TLC5941 LED driver uses a serial data interface to receive grayscale and dot correction data. This application report discusses the hardware and firmware to drive the TLC5941 with a MSP430F427 microcontroller. - TLC5940 dot correction compensates for variations in LED brightnessPDF, 175 Кб, Файл опубликован: 10 окт 2005
- Hardware Design Considerations for a Wireless LED based Display DesignPDF, 682 Кб, Файл опубликован: 11 июн 2014
Scoreboards have different purposes with various features. Scoreboards are typically used for displaying scores of a game played between two teams. These games can be a timed or an untimed event. The application described in this application report creates a multi-sport scoreboard that is cost efficient, portable, and easy to use. The display values on the scoreboard are transmitted wirelessly. - LED Driver--Paralleled Outputs Provide High Current OutputsPDF, 957 Кб, Файл опубликован: 25 сен 2006
This application report describes how to use the TLC5922, TLC5923, and TLC5924 to drive high-current LEDs. These ICs are designed to provide 16 individually controllable constant-current sinks. However, the 16 outputs can be connected in parallel to increase the current drive capability. Paralleling the outputs of these ICs allows the TLC5922, TLC5923, and TLC5924 to drive high-power LEDs such as - Using the TLC5940 with Higher LED Supply Voltages and Series LEDsPDF, 353 Кб, Файл опубликован: 20 авг 2007
This application report describes how to accommodate higher LED supply voltages and increase the number of series LEDs that the TLC5940 can drive. - LED Display System Module Using Cascading TLC5940 DevicesPDF, 496 Кб, Файл опубликован: 6 июл 2006
Described in this document are application ideas and reference designs for the TLC5940 LED driver. The following application example shows the building of a basic module of an LED display system using a cascading connection on n TLC5940 devices connected to a controller. The reference design implements three TLC5940 devices to drive 16 LEDs.
Серия: TLC5940-EP (4)
- TLC5940QPWPREP TLC5940QRHBREP V62/10610-01XE V62/10610-01YE
- Semiconductors > Space & High Reliability > Power Management Products > LED Drivers
V62/1061001YE, V62/10610 01YE
