Datasheet Texas Instruments 5962-9750901Q2A — Даташит
Серия | TLC7733M |
Модель | 5962-9750901Q2A |
![Datasheet Texas Instruments 5962-9750901Q2A](http://www.ti.com/graphics/folders/partimages/TLC7733M.jpg)
Single SVS For 3.3V Systems W/Programmable Time Delay 20-LCCC -55 to 125
MicroPower Supply Voltage Supervisors. datasheet
PDF, 1.9 Мб, Версия: M, Файл опубликован: 19 мар 2012
Купить 5962-9750901Q2A на РадиоЛоцман.Цены — от 3 507 до 243 328 ₽ 7 предложений от 7 поставщиков Volt Supervisor Supply 5V 20-Pin CLLCC | |||
5962-9750901Q2A Texas Instruments | 3 507 ₽ | ||
5962-9750901Q2A Texas Instruments | 3 522 ₽ | ||
5962-9750901Q2A Texas Instruments | по запросу | ||
Pin | 20 | 20 | 20 | 20 |
Package Type | FK | FK | FK | FK |
Industry STD Term | LCCC | LCCC | LCCC | LCCC |
JEDEC Code | S-CQCC-N | S-CQCC-N | S-CQCC-N | S-CQCC-N |
Package QTY | 1 | 1 | 1 | 1 |
Carrier | TUBE | TUBE | TUBE | TUBE |
Маркировка | MFKB | TLC7733 | 5962- | 9750901Q2A |
Width (мм) | 8.89 | 8.89 | 8.89 | 8.89 |
Length (мм) | 8.89 | 8.89 | 8.89 | 8.89 |
Thickness (мм) | 1.83 | 1.83 | 1.83 | 1.83 |
Pitch (мм) | 1.27 | 1.27 | 1.27 | 1.27 |
Max Height (мм) | 2.03 | 2.03 | 2.03 | 2.03 |
Mechanical Data | Скачать | Скачать | Скачать | Скачать |
# of Supplies Monitored | 1 |
Iq(Typ) | 9 uA |
Monitored Voltage 1 (typ)(Nom) | 3.3 В |
Output Driver Type / Reset Output | Active-high,Active-low,Push-pull |
Package Group | LCCC |
Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
Rating | Military |
Reset Threshold Accuracy | 2.4 % |
Threshold Voltage 1(Typ) | 2.93 В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | Programmable ms |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
Watchdog Timer WDI | None sec |
RoHS | See ti.com |
- Reset Circuit for the TMS320C6000 DSP (Rev. A)PDF, 36 Кб, Версия: A, Файл опубликован: 10 июн 1999
This document describes two solutions used to provide a reset circuit to the Texas Instruments (TI)(tm) TMS320C6000 digital signal processor (DSP). One solution sets a supply voltage supervisor, such as the TI TLC7733 and TLC7725, on each of the supply voltages, DVdd and CVdd. Another solution monitors both the 2.5-V/1.8-V and 3.3-V power supplies using a single supervisor such as the TI TPS3707.
Серия: TLC7733M (5)
- 5962-9750901Q2A 5962-9750901QPA TLC7733MFKB TLC7733MJG TLC7733MJGB
- Semiconductors > Space & High Reliability > Power Management Products > Supervisor and Reset ICs
59629750901Q2A, 5962 9750901Q2A
