Datasheet Texas Instruments TLV2314-Q1 — Даташит
Серия | TLV2314-Q1 |
3-MHz, Low-Power, Internal EMI Filter, RRIO, Operational Amplifiers
Купить TLV2314 на РадиоЛоцман.Цены — от 36 до 95 ₽ 17 предложений от 10 поставщиков 3MHz, Low-Power, Low-Noise, RRIO, CMOS Operational Amplifier for Cost-Sensitive Systems 8-SOIC -40℃ to 125℃ | |||
TLV2314IDR Texas Instruments | 36 ₽ | ||
TLV2314IDR Texas Instruments | 37 ₽ | ||
TLV2314IDR Texas Instruments | 58 ₽ | ||
TLV2314IDGK Texas Instruments | 76 ₽ |
TLV2314QDGKRQ1 | TLV2314QDRQ1 | |
Статус продукта | Анонсирован | Анонсирован |
Доступность образцов у производителя | Нет | Нет |
N | 1 | 2 |
Pin | 8 | 8 |
Package Type | DGK | D |
Industry STD Term | VSSOP | SOIC |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Width (мм) | 3 | 3.91 |
Length (мм) | 3 | 4.9 |
Thickness (мм) | .97 | 1.58 |
Pitch (мм) | .65 | 1.27 |
Max Height (мм) | 1.07 | 1.75 |
Parameters / Models | TLV2314QDGKRQ1 | TLV2314QDRQ1 |
Additional Features | Cost Optimized EMI Hardened | Cost Optimized EMI Hardened |
Архитектура | CMOS | CMOS |
CMRR(Min)(dB) | 72 | 72 |
CMRR(Typ)(dB) | 96 | 96 |
GBW(Typ)(MHz) | 3 | 3 |
Iq per channel(Max)(mA) | 0.25 | 0.25 |
Iq per channel(Typ)(mA) | 0.15 | 0.15 |
Number of Channels(#) | 2 | 2 |
Offset Drift(Typ)(uV/C) | 2 | 2 |
Operating Temperature Range(C) | -40 to 125 | -40 to 125 |
Output Current(Typ)(mA) | 20 | 20 |
Package Group | VSSOP | SOIC |
Package Size: mm2:W x L (PKG) | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) |
Rail-to-Rail | In Out | In Out |
Rating | Automotive | Automotive |
Slew Rate(Typ)(V/us) | 1.5 | 1.5 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 5.5 | 5.5 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 1.8 | 1.8 |
Vn at 1kHz(Typ)(nV/rtHz) | 16 | 16 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 3 | 3 |
RoHS | Не совместим | Не совместим |
Бессвинцовая технология (Pb Free) | Нет | Нет |
Серия: TLV2314-Q1 (2)
- Semiconductors> Amplifiers> Operational Amplifiers (Op Amps)> General-Purpose Op Amps
