Datasheet Texas Instruments TLV2461-Q1 — Даташит
СерияTLV2461-Q1
Automotive Low-Power Rail-to-Rail Input/Output Operational Amplifier with Shutdown
TLV246xx-Q1 Low-Power Rail-to-Rail Input/Output Operational Amplifiers With Shutdown datasheet
PDF, 2.1 Мб, Версия: F, Файл опубликован: 7 янв 2016
TLV2461-Q1
T-electron
TLV2461-Q1
TLV2461QDRQ1TLV2461QPWRG4Q1TLV2461QPWRQ1
Статус продуктаСнят с производстваВ производствеСнят с производства
Доступность образцов у производителяНетНетНет
N123
Pin888
Package TypeDPWPW
Industry STD TermSOICTSSOPTSSOP
Маркировка2461Q12461Q1
Width (мм)3.914.44.4
Length (мм)4.933
Thickness (мм)1.5811
Pitch (мм)1.27.65.65
Max Height (мм)1.751.21.2
Package QTY2000
Parameters / ModelsTLV2461QDRQ1
TLV2461QDRQ1
TLV2461QPWRG4Q1
TLV2461QPWRG4Q1
TLV2461QPWRQ1
TLV2461QPWRQ1
Additional FeaturesN/AN/AN/A
Approx. Price (US$)0.79 | 1ku0.79 | 1ku
АрхитектураBipolarBipolarBipolar
CMRR(Min), дБ71
CMRR(Min)(dB)7171
CMRR(Typ), дБ85
CMRR(Typ)(dB)8585
GBW(Typ), МГц6.4
GBW(Typ)(MHz)6.46.4
Input Bias Current(Max), pA14000
Input Bias Current(Max)(pA)1400014000
Iq per channel(Max), мА0.65
Iq per channel(Max)(mA)0.650.65
Iq per channel(Typ), мА0.55
Iq per channel(Typ)(mA)0.550.55
Количество каналов1
Number of Channels(#)11
Offset Drift(Typ), uV/C2
Offset Drift(Typ)(uV/C)22
Рабочий диапазон температур, Cот -40 до 125
Operating Temperature Range(C)-40 to 125-40 to 125
Output Current(Typ), мА80
Output Current(Typ)(mA)6060
Package GroupTSSOPTSSOPTSSOP
Package Size: mm2:W x L, PKG8TSSOP: 19 mm2: 6.4 x 3(TSSOP)
Package Size: mm2:W x L (PKG)8TSSOP: 19 mm2: 6.4 x 3(TSSOP)8TSSOP: 19 mm2: 6.4 x 3(TSSOP)
Rail-to-RailIn
Out
In,OutIn
Out
RatingAutomotiveAutomotiveAutomotive
Slew Rate(Typ), V/us1.6
Slew Rate(Typ)(V/us)1.61.6
Total Supply Voltage(Max), +5V=5, +/-5V=106
Total Supply Voltage(Max)(+5V=5, +/-5V=10)66
Total Supply Voltage(Min), +5V=5, +/-5V=102.7
Total Supply Voltage(Min)(+5V=5, +/-5V=10)2.72.7
Vn at 1kHz(Typ), нВ/rtГц11
Vn at 1kHz(Typ)(nV/rtHz)1111
Vos (Offset Voltage @ 25C)(Max), мВ2
Vos (Offset Voltage @ 25C)(Max)(mV)22
RoHSНе совместимСовместимНе совместим
Бессвинцовая технология (Pb Free)НетНет
Серия: TLV2461-Q1 (3)
  • Semiconductors> Amplifiers> Operational Amplifiers (Op Amps)> Precision Op Amps
На английском языке: Datasheet Texas Instruments TLV2461-Q1
Публикации по теме
