Datasheet Texas Instruments TLV2461M — Даташит
СерияTLV2461M
Single, Low Power, Rail-to-Rail Input/Output Operational Amplifier
Rail-to-Rail Input/Output Operational Amplifiers w/ Shutdown datasheet
PDF, 2.9 Мб, Версия: J, Файл опубликован: 29 фев 2004
TLV2461M
T-electron
TLV2461M
5962-0051203QHATLV2461MUB
N12
Pin1010
Package TypeUU
Industry STD TermCFPCFP
JEDEC CodeS-GDFP-FS-GDFP-F
Package QTY11
CarrierTUBETUBE
МаркировкаTLV2461MTLV2461M
Width (мм)6.356.35
Length (мм)6.356.35
Thickness (мм)1.651.65
Pitch (мм)1.271.27
Max Height (мм)2.032.03
Parameters / Models5962-0051203QHA
5962-0051203QHA
TLV2461MUB
TLV2461MUB
Additional FeaturesN/A
Approx. price, US$34.472 | 100u
АрхитектураBipolarBipolar
CMRR(Min), дБ7171
CMRR(Typ), дБ8585
Основные особенностиN/A
GBW(Typ), МГц6.46.4
IIB(Max), pA14000
Input bias current(Max), pA14000
Input bias current(Typ), pA1300
Iq per channel(Max), мА0.650.65
Iq per channel(Typ), мА0.550.55
Количество каналов1
Number of channels1
Offset Drift(Typ), uV/C2
Offset drift(Typ), uV/C2
Рабочий диапазон температур, Cот -55 до 125
Operating temperature range, C-55 to 125
Output Current(Typ), мА80
Output current(Typ), мА80
Output swing headroom (to negative supply)(Typ), В0.2
Output swing headroom (to positive supply)(Typ), В-0.2
Package GroupCFP|10CFP
Package Size: mm2:W x L, PKGSee datasheet (CFP)
Package size: mm2:W x L, PKG10CFP: 40 mm2: 6.35 x 6.35 (CFP|10)
Rail-to-RailIn,Out
Rail-to-railIn,Out
RatingMilitaryMilitary
Slew Rate(Typ), V/us1.6
Slew rate(Typ), V/us1.6
Total Supply Voltage(Max), +5V=5, +/-5V=106
Total Supply Voltage(Min), +5V=5, +/-5V=102.7
Total supply voltage(Max), +5V=5, +/-5V=106
Total supply voltage(Min), +5V=5, +/-5V=102.7
Vn at 1 kHz(Typ), нВ/rtГц11
Vn at 1kHz(Typ), нВ/rtГц11
Vos (Offset Voltage @ 25C)(Max), мВ2
Vos (offset voltage @ 25 C)(Max), мВ2
RoHSНе совместимSee ti.com
  • TLV2461/62/63/64/65 EMI Immunity Performance (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 14 ноя 2012
Серия: TLV2461M (2)
  • Semiconductors> Space & High Reliability> Amplifier> Operational Amplifiers
На английском языке: Datasheet Texas Instruments TLV2461M
