Datasheet Texas Instruments TLV2463A-Q1 — Даташит
СерияTLV2463A-Q1
Automotive Low-Power Rail-to-Rail Input/Output Operational Amplifier with Shutdown
TLV246xx-Q1 Low-Power Rail-to-Rail Input/Output Operational Amplifiers With Shutdown datasheet
PDF, 2.1 Мб, Версия: F, Файл опубликован: 7 янв 2016
TLV2463A-Q1
T-electron
TLV2463A-Q1
TLV2463AQDRQ1TLV2463AQPWRG4Q1TLV2463AQPWRQ1
Статус продуктаСнят с производстваВ производствеСнят с производства
Доступность образцов у производителяНетНетНет
N123
Pin141414
Package TypeDPWPW
Industry STD TermSOICTSSOPTSSOP
Width (мм)3.914.44.4
Length (мм)8.6555
Thickness (мм)1.5811
Pitch (мм)1.27.65.65
Max Height (мм)1.751.21.2
Package QTY2000
Маркировка2463AQ1
Parameters / ModelsTLV2463AQDRQ1
TLV2463AQDRQ1
TLV2463AQPWRG4Q1
TLV2463AQPWRG4Q1
TLV2463AQPWRQ1
TLV2463AQPWRQ1
Additional FeaturesShutdownShutdownShutdown
Approx. Price (US$)1.59 | 1ku1.59 | 1ku
АрхитектураBipolarBipolarBipolar
CMRR(Min), дБ71
CMRR(Min)(dB)7171
CMRR(Typ), дБ85
CMRR(Typ)(dB)8585
GBW(Typ), МГц6.4
GBW(Typ)(MHz)6.46.4
Input Bias Current(Max), pA14000
Input Bias Current(Max)(pA)1400014000
Iq per channel(Max), мА0.65
Iq per channel(Max)(mA)0.650.65
Iq per channel(Typ), мА0.55
Iq per channel(Typ)(mA)0.550.55
Количество каналов2
Number of Channels(#)22
Offset Drift(Typ), uV/C2
Offset Drift(Typ)(uV/C)22
Рабочий диапазон температур, Cот -40 до 125
Operating Temperature Range(C)-40 to 125-40 to 125
Output Current(Typ), мА80
Output Current(Typ)(mA)6060
Package GroupTSSOPTSSOPTSSOP
Package Size: mm2:W x L, PKG14TSSOP: 32 mm2: 6.4 x 5(TSSOP)
Package Size: mm2:W x L (PKG)14TSSOP: 32 mm2: 6.4 x 5(TSSOP)14TSSOP: 32 mm2: 6.4 x 5(TSSOP)
Rail-to-RailIn
Out
In,OutIn
Out
RatingAutomotiveAutomotiveAutomotive
Slew Rate(Typ), V/us1.6
Slew Rate(Typ)(V/us)1.61.6
Total Supply Voltage(Max), +5V=5, +/-5V=106
Total Supply Voltage(Max)(+5V=5, +/-5V=10)66
Total Supply Voltage(Min), +5V=5, +/-5V=102.7
Total Supply Voltage(Min)(+5V=5, +/-5V=10)2.72.7
Vn at 1kHz(Typ), нВ/rtГц11
Vn at 1kHz(Typ)(nV/rtHz)1111
Vos (Offset Voltage @ 25C)(Max), мВ1.5
Vos (Offset Voltage @ 25C)(Max)(mV)1.51.5
RoHSНе совместимСовместимНе совместим
Бессвинцовая технология (Pb Free)НетНет
Серия: TLV2463A-Q1 (3)
  • Semiconductors> Amplifiers> Operational Amplifiers (Op Amps)> Precision Op Amps
На английском языке: Datasheet Texas Instruments TLV2463A-Q1
Публикации по теме
