Datasheet Texas Instruments TLV2463AM — Даташит
СерияTLV2463AM
Dual Low-Power, Rail-to-Rail Input/Output Operational Amplifier w/Shutdown
Rail-to-Rail Input/Output Operational Amplifiers w/ Shutdown datasheet
PDF, 2.7 Мб, Версия: J, Файл опубликован: 29 фев 2004
TLV2463AM
T-electron
TLV2463AM
TLV2463AMJ
Статус продуктаВ производстве
TLV2463AMJ
N1
Pin14
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
МаркировкаTLV2463AMJ
Width (мм)6.67
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Parameters / ModelsTLV2463AMJ
TLV2463AMJ
Additional FeaturesShutdown
АрхитектураBipolar
CMRR(Min), дБ71
CMRR(Typ), дБ85
GBW(Typ), МГц6.4
IIB(Max), pA14000
Iq per channel(Max), мА0.65
Iq per channel(Typ), мА0.55
Количество каналов2
Offset Drift(Typ), uV/C2
Рабочий диапазон температур, Cот -55 до 125
Output Current(Typ), мА80
Package GroupCDIP
Package Size: mm2:W x L, PKGSee datasheet (CDIP)
Rail-to-RailIn,Out
RatingMilitary
Slew Rate(Typ), V/us1.6
Total Supply Voltage(Max), +5V=5, +/-5V=106
Total Supply Voltage(Min), +5V=5, +/-5V=102.7
Vn at 1kHz(Typ), нВ/rtГц11
Vos (Offset Voltage @ 25C)(Max), мВ1.5
TLV2463AMJ
RoHSSee ti.com
  • Using the TLV246x as a Multiplexer with Gain in a Data Acquisition System
    PDF, 62 Кб, Файл опубликован: 14 дек 1998
    Using the TLV246x as a multiplexer lends itself to certain applications where system signals are only measured at power up, or are measured infrequently or periodically at slow sampling rates during operation. This application report describes the circuit and discusses measurement of key parameters.
  • TLV2461/62/63/64/65 EMI Immunity Performance (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 14 ноя 2012
Серия: TLV2463AM (1)
  • Semiconductors> Space & High Reliability> Amplifier> Operational Amplifiers
На английском языке: Datasheet Texas Instruments TLV2463AM
