Datasheet Texas Instruments TLV320AIC24IPFB — Даташит
Серия | TLV320AIC24 |
Модель | TLV320AIC24IPFB |
Low-Power Stereo Voice Band CODEC 48-TQFP -40 to 85
Low Power Highly-Integrated Programmable 16-Bit 26-KSPS Dual Channel CODEC datasheet
PDF, 1.6 Мб, Версия: D, Файл опубликован: 12 апр 2005
Купить TLV320AIC24IPFB на РадиоЛоцман.Цены — от 357 до 2 157 ₽ 17 предложений от 14 поставщиков Audio Codec 2ADC / 2DAC 16Bit 48Pin TQFP Tray | |||
TLV320AIC24IPFB Texas Instruments | от 357 ₽ | ||
TLV320AIC24IPFB-1 Texas Instruments | 707 ₽ | ||
TLV320AIC24IPFB Texas Instruments | 839 ₽ | ||
TLV320AIC24IPFB Texas Instruments | по запросу |
Статус продукта | NRND (Не рекомендуется для новых разработок) |
Pin | 48 |
Package Type | PFB |
Industry STD Term | TQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 250 |
Carrier | JEDEC TRAY (10+1) |
Маркировка | 320AIC24I |
Width (мм) | 7 |
Length (мм) | 7 |
Thickness (мм) | 1 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | TLV320AIC24KIPFB |
Replacement Code | F |
- TMS320C54xx McBSP to TLV320AIC24 InterfacePDF, 272 Кб, Файл опубликован: 30 сен 2003
This application note describes a method for interfacing the TMS320C5400 multichannel buffer serial ports (McBSP) to the TLV320AIC24.The TLV320AIC24 innovation is the smart-time division, multiplexed serial port (SMARTDMв„ў) that optimizes the DSP performance with an advanced synchronous 4-wire serial port in TDM format for glue-free interface to popular DSPs (i.e., C5000, C6000) and mi - Hands-Free Kit: Integration of the AIC24 Driver in RF3PDF, 323 Кб, Файл опубликован: 18 дек 2003
- Demo/Test CODEC System with TLV320AIC20/21/24/25 EVMPDF, 141 Кб, Файл опубликован: 26 авг 2002
A demo/test system has been built as a simple example for using the TLV320AIC20/21/24/25 codecs. The hardware part of the system includes the ?AIC20/21/24/25 EVM boards, an AIC development interface board, and a TMS320C5402 DSP DSK board. The C54xx software, in assembly and C, is implemented on the ?C5402 DSP. A 2-device, 4-channel and a 6-device, 12-channel codec system are presented in this appl - Interface With Voice-Band Codecs Using I2CPDF, 231 Кб, Файл опубликован: 19 мар 2003
This application report builds up an I2C port from two pins in a McBSP, develops the I2C software driver, and interfaces with the voice-band codec(s), including TLV320AIC1103/1109 /1110, TLV320AIC12/ 13/ 14/ 15, or TLV320AIC20/ 21/ 24/ 25 devices. The I2C driverdesign is discussed in details and the corresponding C code is presented. - Common Sample Rate Selection For TLV320AIC12/13/14/15/20/21/24/25 CodecsPDF, 103 Кб, Файл опубликован: 30 апр 2003
This application report intends to help TI voice-band codec users to quickly and properly select the commonly used master clock frequency (MCLK) and the corresponding frequency dividers, M, N, and P, which is the first step For utilizing TI?s TLV320AIC12 /13 /14 /15 /20 /21 /24 /25 voice-band codecs.
Серия: TLV320AIC24 (6)
- Semiconductors > Audio > Audio Converters > Audio CODEC
