Datasheet Texas Instruments TMP451 — Даташит
Серия | TMP451 |
1.7V-Capable Remote and Local Temp Sensor with Auto Beta, N-Factor, Filter, and Series-R Correction
TMP451 В±1В°C Remote and Local Temperature Sensor With О·-Factor and Offset Correction, Series-Resistance Cancellation, and Programmable Digital Filter datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 29 сен 2014
Купить TMP451 на РадиоЛоцман.Цены — от 35 до 131 ₽ 21 предложений от 14 поставщиков 1.7V-Capable emote and Local Temp Sensor with Auto Beta, N-Factor, Filter, and Series- Correction 8-WSON -40℃ to 125℃ | |||
TMP451AIDQFR Texas Instruments | от 35 ₽ | ||
TMP451AQDQFRQ1 Texas Instruments | 50 ₽ | ||
TMP451AIDQFT Texas Instruments | 68 ₽ | ||
TMP451AIDQFT Texas Instruments | по запросу |
TMP451AIDQFR | TMP451AIDQFT | |
Статус продукта | В производстве | В производстве |
Доступность образцов у производителя | Да | Нет |
N | 1 | 2 |
Pin | 8 | 8 |
Package Type | DQF | DQF |
Industry STD Term | WSON | WSON |
JEDEC Code | S-PSSO-N | S-PSSO-N |
Package QTY | 3000 | 250 |
Carrier | LARGE T&R | SMALL T&R |
Маркировка | T451 | T451 |
Width (мм) | 2 | 2 |
Length (мм) | 2 | 2 |
Thickness (мм) | .75 | .75 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | .8 | .8 |
Parameters / Models | TMP451AIDQFR | TMP451AIDQFT |
Interface | I2C,SMBus | I2C,SMBus |
Local Sensor Accuracy(Max), +/- C | 1 | 1 |
Рабочий диапазон температур, C | от -40 до 125 | от -40 до 125 |
Package Group | WSON | WSON |
Package Size: mm2:W x L, PKG | See datasheet (WSON) | See datasheet (WSON) |
Rating | Catalog | Catalog |
Remote Channel | 1 | 1 |
Remote Diode Temp Range for Listed Accuracy, C | -55 to 150 | -55 to 150 |
Remote Sensor Accuracy(Max), +/- C | 1 | 1 |
Remote Sensor Correction | n-Factor Correction | n-Factor Correction |
Remote Temp Resolution(Max), bits | 12 | 12 |
Special Features | Dynamic Averaging,Programmable Alert,Shutdown | Dynamic Averaging,Programmable Alert,Shutdown |
Supply Current(Typ), uA | 35 | 35 |
Supply Voltage(Max), В | 3.6 | 3.6 |
Supply Voltage(Min), В | 1.7 | 1.7 |
- Optimizing Remote Diode Temperature Sensor DesignPDF, 1.2 Мб, Файл опубликован: 19 янв 2017
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: TMP451 (2)
- Semiconductors> Sensing Products> Temperature Sensors> Remote / Multi-channel Temperature Sensors
