Datasheet Texas Instruments TMS320C6720 — Даташит
Серия | TMS320C6720 |
Floating-Point Digital Signal Processor
TMS320C6727B, TMS320C6726B, TMS320C6722B, TMS320C6720 Floating-Point DSPs datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 11 июл 2008
Купить TMS320C6720 на РадиоЛоцман.Цены — от 640 до 2 725 ₽ 20 предложений от 16 поставщиков Процессоры и контроллеры цифровых сигналов (DSP, DSC) Floating-Point Dig Signal Proc | |||
TMS320C6720BRFP200 Texas Instruments | 640 ₽ | ||
TMS320C6720BRFP200 Texas Instruments | 787 ₽ | ||
TMS320C6720BRFP200 Texas Instruments | 1 584 ₽ | ||
TMS320C6720ZDHA250 Texas Instruments | по запросу |
TMS320C6720BRFP200 | |
Статус продукта | В производстве |
N | 1 |
Pin | 144 |
Package Type | RFP |
Industry STD Term | HTQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 60 |
Carrier | JEDEC TRAY (10+1) |
Маркировка | C6720BRFP |
Width (мм) | 20 |
Length (мм) | 20 |
Thickness (мм) | 1 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Parameters / Models | TMS320C6720BRFP200 |
DSP | 1 C67x |
Rating | Catalog |
- Configuring External Interrupts on TMS320C672x DevicesPDF, 730 Кб, Файл опубликован: 11 июл 2008
Every real-time embedded system needs to be able to interact to events associated with the external world in a timely manner; for this, typically every digital signal processor (DSP) device features one or more dedicated pins, which are used for carrying these external signals, called interrupts, inside the device for further processing by the application. The TMS320C672x generation of processors - Using ROM Contents on TMS320C672xPDF, 92 Кб, Файл опубликован: 5 фев 2008
This application report explains how to configure an application based on pure software libraries and routines and how to properly use the provided ROM contents for the TMS320C672x DSP generation of devices. Several software examples are provided, explaining the process in progressive steps. - How to Create Delay-based Audio Effects on a TMS320C6727 DSPPDF, 600 Кб, Файл опубликован: 1 ноя 2005
TMS320C672x is a floating point device family from Texas Instruments that provides high quality audio performance at low prices. The price/performance ratio makes C672x well suited for numerous audio applications. This application note shows how to use C672x to efficiently create delay-based audio effects. The application note explains:How to leverage the data movement accelerator (dM - TMS320C672x Hardware Designer's Resource Guide (Rev. A)PDF, 87 Кб, Версия: A, Файл опубликован: 22 сен 2006
The DSP Hardware Designer's Resource Guide is organized by development flow and functional areas to make your design effort as seamless as possible. Topics covered include getting started, board design, system testing, and checklists to aid in your initial design and debug efforts. Each section includes pointers to valuable information including technical documentation, models, symbols, and refere - C9230C100 TMS320C672x Floating-Point Digital Signal Processor ROM (Rev. C)PDF, 60 Кб, Версия: C, Файл опубликован: 25 сен 2006
Describes the features of the C9230C100 TMS320C672x digital signal processor ROM. The system level patch, bootloader utilities and example code, can be downloaded from this link: http://www-s.ti.com/sc/psheets/sprc203/sprc203.zip. - TMS320C672x Power Consumption Summary (Rev. B)PDF, 55 Кб, Версия: B, Файл опубликован: 22 сен 2006
This document discusses the power consumption of the Texas Instruments TMS320C672x digital signal processor (DSP). Power consumption on TMS320C67xв„ў devices is highly application-dependent. A spreadsheet is provided to model power consumption for the user’s application. To get good results from the spreadsheet, realistic usage parameters must be entered. The low-core voltage and other power d - Using the TMS320C672x Bootloader (Rev. D)PDF, 456 Кб, Версия: D, Файл опубликован: 10 сен 2009
This application report describes the design details of the TMS320C672x bootloader and describes a set of software utilities designed to facilitate formatting of application code for use with the bootloader.This application report contains a system level patch, the bootloader utilities and project code that can bedownloaded from this link: - TMS320C6713 to TMS320C672x Migration GuidePDF, 182 Кб, Файл опубликован: 23 май 2005
- Thermal Considerations for the DM64xx, DM64x, and C6000 DevicesPDF, 127 Кб, Файл опубликован: 20 май 2007
As integrated circuit (IC) components become more complex, the challenge of producing an end product with superior thermal performance increases. Thermal performance is a system level concern, impacted by IC packaging as well as by printed circuit board (PCB) design. This application report addresses the thermal considerations for the TMS320DM64xx, TMS320DM64x, and TMS320C6000в„ў DSP devices. - Common Object File Format (COFF)PDF, 125 Кб, Файл опубликован: 15 апр 2009
- Introduction to TMS320C6000 DSP OptimizationPDF, 535 Кб, Файл опубликован: 6 окт 2011
Серия: TMS320C6720 (1)
- Semiconductors> Processors> Digital Signal Processors> C6000 DSP> Other C6000 DSP
