Datasheet Texas Instruments TMS320F280260 — Даташит
Серия | TMS320F280260 |
Piccolo Microcontroller
TMS320F2802x0 Piccolo Microcontrollers datasheet
PDF, 1.3 Мб, Версия: B, Файл опубликован: 27 сен 2013
Купить TMS320F280260 на РадиоЛоцман.Цены — от 74 до 584 ₽ 15 предложений от 14 поставщиков C28x C2000TMC28x PiccoloTMMicrocontroller IC 32-Bit Single-Core 50MHz 16KB (8K x 16) FLASH 38-TSSOP | |||
TMS320F280260DAS Texas Instruments | 74 ₽ | ||
TMS320F280260PTT Texas Instruments | 250 ₽ | ||
TMS320F280260PTT Texas Instruments | 361 ₽ | ||
TMS320F280260PTS Texas Instruments | по запросу |
TMS320F280260PTT | |
Статус продукта | В производстве |
N | 1 |
Pin | 48 |
Package Type | PT |
Industry STD Term | LQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 250 |
Маркировка | S320F 980 |
Width (мм) | 7 |
Length (мм) | 7 |
Thickness (мм) | 1.4 |
Pitch (мм) | .5 |
Max Height (мм) | 1.6 |
Mechanical Data | Скачать |
Parameters / Models | TMS320F280260PTT |
ADC, Ch | 6,8 |
ADC Resolution | 12-bit |
CPU | C28x |
Comparators | 2 |
FPU | No |
Flash, KB | 16 |
Тактовая частота, МГц | 50 |
I2C | 1 |
Рабочий диапазон температур, C | от -40 до 105 |
PWM, Ch | 6 |
Pin/Package | 48LQFP |
RAM, KB | 6 |
SPI | 1 |
Total Processing, MIPS | 50 |
UART, SCI | 1 |
- Multi-DC/DC Conversion & Color LED Control Integrated on a C2000 MicrocontrollerPDF, 3.7 Мб, Файл опубликован: 1 фев 2012
This application report presents a solution to control an LED lighting system using TMS320F2802x microcontrollers. The Piccoloв„ў TMS320F2802x series of devices are part of the family of C2000 microcontrollers, which enables cost-effective designs of LED lighting systems. With these devices, it is possible to control multiple strings of LEDs in an efficient and very accurate way. In addition t - High-Voltage Half-Bridge LLC Resonant DC/DC Conv SW w/ Synch Rectification KitPDF, 825 Кб, Файл опубликован: 2 июл 2013
This application report presents a solution to control a half-bridge LLC resonant DC/DC converter with synchronous rectification system using TMS320F2802x microcontrollers. The Piccolo;trade; TMS320F2802x series of devices are part of the family of C2000;trade; microcontrollers that enable cost-effective design of power supply systems. With these devices, it is possible to control power stages in - Serial Flash Programming of C2000 Microcontrollers (Rev. B)PDF, 387 Кб, Версия: B, Файл опубликован: 8 фев 2017
Often times, embedded processors must be programmed in situations where JTAG is not a viable optionfor programming the target device. When this is the case, the engineer must rely on some type of serial programming solution. C2000 devices aid in this endeavor through their inclusion of several program loading utilities included in ROM. These utilities are useful, but only solve half of the progr - Accelerators: Enhancing the Capabilities of the C2000 MCU Family Technical Brief (Rev. A)PDF, 155 Кб, Версия: A, Файл опубликован: 8 ноя 2016
Engineers designing real-time control systems are constantly faced with the challenge of optimizing performance. These systems require minimal processing latency in order to meet the control loop performance specifications. At the heart of the control systems are math intensive algorithms which are used to calculate the control signals. Utilizing a microcontroller (MCU) that can quickly and effici - EEPROM Emulation With the TMS320F28xxx DSCsPDF, 407 Кб, Файл опубликован: 21 сен 2009
Many applications require storing small quantities of system related data (e.g., calibration values, device configuration) in a non-volatile memory, so that it can be used or modified and reused even after power cycling the system. EEPROMs are primarily used for this purpose. EEPROMs have the ability to erase and write individual bytes of memory many times over and the programmed locations retain - Programming External Nonvolatile Memory Using SDFlash for TMS320C28x DevicesPDF, 2.0 Мб, Файл опубликован: 16 ноя 2009
The C28xxx generation of microcontrollers can connect to external nonvolatile memory through a variety of interfaces including parallel, serial peripheral interface (SPI), and inter-integrated circuit (I2C). This application report discusses how to write drivers for your external nonvolatile memory to allow for in-place programming using SDFlash, an application provided by Spectrum Digital, Inc. A - TPS75005 Quick-Start Guide with C2000 ControllersPDF, 129 Кб, Файл опубликован: 17 янв 2012
The TPS75005 is a complete power management solution for C2000 controllers from Texas Instruments. This document illustrates how to attach the TPS75005 to a C2000 controller.
Серия: TMS320F280260 (1)
- Semiconductors> Microcontrollers (MCU)> Performance MCUs> Real-time Control> Piccolo F2802x/3x/5x/6x/7x
