Datasheet Texas Instruments TMS320LF2402 — Даташит
Серия | TMS320LF2402 |
16-bit fixed point DSP with Flash
Купить TMS320LF2402 на РадиоЛоцман.Цены — от 106 до 1 525 ₽ 23 предложений от 20 поставщиков C2xx DSP C2000TMC24x 16-Bit Microcontroller IC 16-Bit 40MHz 16KB (8K x 16) FLASH 64-QFP (14x20) | |||
TMS320LF2402APGA Texas Instruments | 106 ₽ | ||
TMS320LF2402APGAR Texas Instruments | от 357 ₽ | ||
TMS320LF2402APGA Texas Instruments | по запросу | ||
TMS320LF2402PGA | TMS320LF2402PGS | |
Статус продукта | Снят с производства | Снят с производства |
Доступность образцов у производителя | Нет | Нет |
N | 1 | 2 |
Pin | 64 | 64 |
Package Type | PG | PG |
Industry STD Term | QFP | QFP |
JEDEC Code | R-PQFP-G | R-PQFP-G |
Маркировка | 320LF2402PGA | 320LF2402PGS |
Width (мм) | 14 | 14 |
Length (мм) | 20 | 20 |
Thickness (мм) | 2.7 | 2.7 |
Pitch (мм) | 1 | 1 |
Max Height (мм) | 3.1 | 3.1 |
RoHS | Не совместим | Не совместим |
Бессвинцовая технология (Pb Free) | Нет | Нет |
- DSP Solution for Permanent Magnet Synchronous MotorPDF, 210 Кб, Файл опубликован: 1 янв 1996
This document presents a solution to control a permanent magnet synchronous motor using the TMS320C24x. This new family of DSPs enables cost-effective design of intelligent controllers for brushless motors which can fulfill enhanced operations, consisting of fewer system components, lower system cost and increased performances. The control method presented relies on the field orientated control (F - DSP Solution for AC Induction MotorPDF, 183 Кб, Файл опубликован: 1 янв 1996
The Motor Control industry is a strong aggressive sector. Each industry to remain competitive, must reduce costs but also has to answer to power consumption reduction and EMI radiation reduction issues imposed by governments and power plant lobbies. The results of these constraining factors are the need of enhanced algorithms. DSP technology allows to achieve both, a high level of performance as - Implementation of a Speed Controlled Brushless DC Drive Using TMS320F240PDF, 157 Кб, Файл опубликован: 1 янв 1997
The DSP Controller TMS320F240 from Texas Instruments is suitable for a wide range of motor drives. TMS320F240 provides a single chip solution by integrating on-chip not only a high computational power but, also, all the peripherals necessary for electric motor control. The main benefits are increased system reliability and cost reduction of the overall system. The present application note describ
Серия: TMS320LF2402 (2)
- Semiconductors> Microcontrollers (MCU)> Performance MCUs> Real-time Control> C24x 16-bit Series
