Datasheet Texas Instruments TMS320TCI6484 — Даташит
Серия | TMS320TCI6484 |
Communications Infrastructure Digital Signal Processor
TMS320TCI6484 Communications Infrastructure Digital Signal Processor (Rev. E)
PDF, 3.0 Мб, Версия: E, Файл опубликован: 30 окт 2009
Купить TMS320TCI6484 на РадиоЛоцман.Цены — от 2 963 до 319 101 ₽ 8 предложений от 8 поставщиков Микросхема: DIGITAL SIGNAL PROCESSORS | |||
TMS320TCI6484CCMHV Texas Instruments | 2 963 ₽ | ||
TMS320TCI6484CCMHV Texas Instruments | 3 027 ₽ | ||
TMS320TCI6484CCMHV Texas Instruments | 8 950 ₽ | ||
TMS320TCI6484CCMHV Texas Instruments | по запросу |
TMX320TCI6484GMH | |
Статус продукта | Снят с производства |
N | 1 |
Pin | 688 |
Package Type | GMH |
Маркировка | TMX320TCI6484 |
Width (мм) | 23 |
Length (мм) | 23 |
Thickness (мм) | 2.35 |
Mechanical Data | Скачать |
RoHS | Не совместим |
- TI Accelerates Femtocell Deployments with DSP SolutionPDF, 192 Кб, Файл опубликован: 24 ноя 2008
- TMS320TCI6484 Power Consumption Summary (Rev. A)PDF, 180 Кб, Версия: A, Файл опубликован: 25 мар 2011
This document discusses the power consumption of the Texas Instruments TMS320C6484 digital signal processor (DSP). The power consumption of the device is highly application-dependent. Therefore, a power spreadsheet that estimates power consumption is provided along with this application report. This spreadsheet can be used to model power consumption for user applications such as power supply desig - TMS320TCI6484 Memory Access PerformancePDF, 355 Кб, Файл опубликован: 30 июн 2009
The TMS320TCI6484 has 32KB L1D SRAM, 32KB L1P SRAM and 2MB L2 SRAM. A 32-bit 667MHz DDR2 SDRAM interface is provided on the DSP to support up to 512MB of external memory.Memory access performance is very critical for software running on the DSP. On the TCI6484 DSP, all the memories can be accessed by DSP cores and multiple DMA masters.The DSP core is capable of performing up to 128 bits - TMS320C6457/TMS320TCI6484/TMS320TCI6487/88 DDR2 Implementation Guidelines (Rev. D)PDF, 139 Кб, Версия: D, Файл опубликован: 28 янв 2010
This document provides implementation instructions for the DDR2 interface contained on the C6457/TCI6484/TCI6487/88 DSP. - TMS320TCI6484 and TMS320C6457 SERDES Implementation Guidelines (Rev. A)PDF, 245 Кб, Версия: A, Файл опубликован: 8 окт 2009
This document contains implementation instructions for the two serializer/deserializer-based interfaces (SerDes) on the TMS320TCI6484 and TMS320C6457 DSP devices:Serial RapidIOВ® (SRIO)Serial Gigabit Media Independent Interface (SGMII) - TMS320TCI6484 and TMS320C6457 DSPs Hardware Design Guide (Rev. B)PDF, 648 Кб, Версия: B, Файл опубликован: 8 окт 2009
This application note describes hardware system design considerations for the TMS320TCI6484 and TMS320C6457 DSPs. - Tuning VCP2 and TCP2 Bit Error Rate PerformancePDF, 293 Кб, Файл опубликован: 11 фев 2011
In most customer applications, a high level of decoding bit error rate (BER) performance is required. Since Convolutional codes and Turbo codes are widely used in wireless communication systems, TI DSPs integrate two high-performance embedded coprocessors (enhanced Viterbi decoder coprocessor and enhanced Turbo decoder coprocessor) that significantly speed up channel-decoding operations on-chip.Error Detection and Correction Mechanism of TMS320C64x+/C674x (Rev. A)PDF, 80 Кб, Версия: A, Файл опубликован: 19 июл 2013
This application report describes the error detection and correction mechanism of the C64x+/C674x megamodule L1P and L2 memories implemented on some devices. Depending on the type of application, these mechanisms are used to either provide diagnostic measures to detect faults in the memory that could lead to unacceptable risk for the user or to increase the availability of the system.TMS320C64x to TMS320C64x+ CPU Migration Guide (Rev. A)PDF, 310 Кб, Версия: A, Файл опубликован: 20 окт 2005
This document describes migration from the Texas Instruments TMS320C64xв„ў digital signal processor (DSP) to the TMS320C64x+в„ў DSP. The objective of this document is to indicate differences between the two cores and to briefly describe new features. Functionality in the devices that is identical is not included. For detailed information about either device, see the TMS320C64x/C64x+ DSPМодельный ряд
Серия: TMS320TCI6484 (1)Классификация производителя
- Semiconductors> Processors> Other Processors
На английском языке: Datasheet Texas Instruments TMS320TCI6484
