Datasheet Texas Instruments TMS470R1A128 — Даташит
Серия | TMS470R1A128 |
16/32-Bit RISC Flash Microcontroller
Купить TMS470R1A128 на РадиоЛоцман.Цены — от 75 до 512 ₽ 15 предложений от 15 поставщиков ARM7® TMS470 Microcontroller IC 16/32-Bit 48MHz 128KB (128K x 8) FLASH 100-LQFP (14x14) | |||
TMS470R1A128PZ Texas Instruments | 75 ₽ | ||
TMS470R1A128PZ-T Texas Instruments | 418 ₽ | ||
TMS470R1A128PZ-T Texas Instruments | 512 ₽ | ||
TMS470R1A128 Texas Instruments | по запросу |
TMS470R1A128PZ-T | |
Статус продукта | Не рекомендуется для новых разработок |
N | 1 |
Pin | 100 |
Package Type | PZ |
Industry STD Term | LQFP |
JEDEC Code | S-PQFP-G |
Маркировка | 470R1A128PZ-T |
Width (мм) | 14 |
Length (мм) | 14 |
Thickness (мм) | 1.4 |
Pitch (мм) | .5 |
Max Height (мм) | 1.6 |
Mechanical Data | Скачать |
RoHS | Не совместим |
- Important ARM Ltd Application Notes for TI Hercules ARM Safety MCUsPDF, 61 Кб, Файл опубликован: 17 ноя 2011
The purpose of this application report is to offer a convenient collection of references to application notes posted by ARM Ltd that apply to TI’s Hercules ARM Safety Microcontrollers. The document contains links directly to the ARM documents in the ARM On-Line InfoCenter as well as re-prints the ARM introduction chapter to help you better determine if you want to investigate further. - High End Timer (HET) Getting Started GuidePDF, 226 Кб, Файл опубликован: 10 июн 2005
This document serves as a guide to begin developing designs with the High End Timer (HET) advanced intelligent timer module. This timer module provides sophisticated timing functions for real-time applications. The following pages will cover a step-by-step process to program the HET. Starting with the setup for the IAR tools, descriptions of the code for the main program necessary to load the HET - 3.3 V I/O Considerations for Hercules Safety MCUs (Rev. A)PDF, 103 Кб, Версия: A, Файл опубликован: 6 сен 2011
As new generations of microcontrollers lower their supply voltages from 5 V to 3.3 V and beyond, issues with interfacing and noise are increasing. This application report presents cost-effective interfacing techniques for inputs and outputs of 3.3 V microprocessors in an automotive environment. In addition, concerns about 3.3 V analog-to-digital converters (ADC) are discussed.
Серия: TMS470R1A128 (1)
- Semiconductors> Microcontrollers (MCU)> Other Microcontrollers> TMS470 ARM7TDMIВ®-Based Industrial MCUs
