Datasheet Microchip ATTINY10-MAHR — Даташит
Производитель | Microchip |
Серия | ATtiny10 |
Модель | ATTINY10-MAHR |
The high-performance, low-power Microchip 8-bit AVR RISC-based microcontroller combines 1KB ISP flash memory, 32B SRAM, four general purpose I/O lines, 16 general purpose working registers, a 16-bit timer/counter with two PWM channels, internal and external interrupts, programmable watchdog timer with internal oscillator, an internal calibrated oscillator, a 4-channel/8-bit A/D converter, and four software selectable power saving modes
Datasheet ATtiny4, ATtiny5, ATtiny9, ATtiny10. Appendix A. Specification at 125C
PDF, 1.2 Мб, Файл опубликован: 1 авг 2011, Страниц: 34
8-bit AVR Microcontroller with 512/1024 Bytes In-System Programmable Flash
Datasheet ATtiny4, ATtiny5, ATtiny9, ATtiny10. Complete Datasheet
PDF, 2.5 Мб, Файл опубликован: 10 дек 2016, Страниц: 207
Datasheet ATtiny4, ATtiny5, ATtiny9, ATiny10. Summary Datasheet
PDF, 341 Кб, Файл опубликован: 10 дек 2016, Страниц: 17
Atmel 8-bit AVR Microcontroller with 512/1024 Bytes In-System Programmable Flash
Купить ATTINY10-MAHR на РадиоЛоцман.Цены — от 32 до 152 ₽ 24 предложений от 15 поставщиков AVR AVR® ATtiny Microcontroller IC 8-Bit 12MHz 1KB (512 x 16) FLASH 8-UDFN, USON | |||
ATTINY10-MAHR Microchip | 32 ₽ | ||
ATTINY10-MAHR Microchip | 33 ₽ | ||
ATTINY10-MAHR Atmel | по запросу |
Корпус | UDFN |
ADC Input | 4 |
ADC with Computation | No |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit AVR |
CRC | No |
Class B Hardware | No |
High Voltage Capable | No |
Internal Oscillator | Yes |
Lead Count | 8 |
Math Accelerator | No |
Max 16-Bit Digital Timers | 1 |
Max ADC Resolution | 8 Bits |
Max CPU Speed | 12 МГц |
Max PWM outputs | 2 including complementary |
Количество компараторов | 1 |
Package Width | 2x2x0.6mm |
Peripheral Pin Select / Pin Muxing | No |
Pin count | 6 |
Размер памяти программ | 1 KB |
SRAM | 32 Bytes |
Temp Range Max | 125 |
Temp Range Min | -40 |
Zero Cross detect | No |
Серия: ATtiny10 (3)
- ATTINY10-MAHR ATTINY10-TS8R ATTINY10-TSHR
- Microcontrollers > 8-bit Microcontrollers
ATTINY10MAHR, ATTINY10 MAHR
