Datasheet Microchip ATtiny10 — Даташит
Производитель | Microchip |
Серия | ATtiny10 |
The high-performance, low-power Microchip 8-bit AVR RISC-based microcontroller combines 1KB ISP flash memory, 32B SRAM, four general purpose I/O lines, 16 general purpose working registers, a 16-bit timer/counter with two PWM channels, internal and external interrupts, programmable watchdog timer with internal oscillator, an internal calibrated oscillator, a 4-channel/8-bit A/D converter, and four software selectable power saving modes
Datasheet ATtiny4, ATtiny5, ATtiny9, ATtiny10. Appendix A. Specification at 125C
PDF, 1.2 Мб, Файл опубликован: 1 авг 2011, Страниц: 34
8-bit AVR Microcontroller with 512/1024 Bytes In-System Programmable Flash
Datasheet ATtiny4, ATtiny5, ATtiny9, ATtiny10. Complete Datasheet
PDF, 2.5 Мб, Файл опубликован: 10 дек 2016, Страниц: 207
Datasheet ATtiny4, ATtiny5, ATtiny9, ATiny10. Summary Datasheet
PDF, 341 Кб, Файл опубликован: 10 дек 2016, Страниц: 17
Atmel 8-bit AVR Microcontroller with 512/1024 Bytes In-System Programmable Flash
Купить ATtiny10 на РадиоЛоцман.Цены — от 20 до 135 ₽ 41 предложений от 24 поставщиков IC: микроконтроллер AVR; SRAM: 32Б; Flash: 1kБ; SOT23-6; 1,8÷5,5ВDC | |||
ATtiny10-TSHR Atmel | 20 ₽ | ||
ATtiny10-TSHR Microchip | 26 ₽ | ||
ATTINY10-TS8R Microchip | 30 ₽ | ||
ATTINY10-MAHR | ATTINY10-TS8R | ATTINY10-TSHR | |
N | 1 | 2 | 3 |
Корпус | UDFN | SOT-23 | SOT-23 |
Parameters / Models | ATTINY10-MAHR | ATTINY10-TS8R | ATTINY10-TSHR |
ADC Input | 4 | 4 | 4 |
ADC with Computation | No | No | No |
Angular Timer | No | No | No |
Архитектура | 8 | 8 | 8 |
CPU Type | 8-bit AVR | 8-bit AVR | 8-bit AVR |
CRC | No | No | No |
Class B Hardware | No | No | No |
High Voltage Capable | No | No | No |
Internal Oscillator | Yes | Yes | Yes |
Internal Voltage Reference, Bandgap | Yes | Yes | Yes |
Lead Count | 8 | 6 | 6 |
Math Accelerator | No | No | No |
Max 16-Bit Digital Timers | 1 | 1 | 1 |
Max ADC Resolution, Bits | 8 | 8 | 8 |
Max CPU Speed, МГц | 12 | 12 | 12 |
Max PWM outputs, including complementary | 2 | 2 | 2 |
Количество компараторов | 1 | 1 | 1 |
Operation Voltage Max, В | 5.5 | 5.5 | 5.5 |
Operation Voltage Min, В | 1.8 | 1.8 | 1.8 |
Package Width | 2x2x0.6mm | 1.6x2.9x1.3mm | 1.6x2.9x1.3mm |
Peripheral Pin Select / Pin Muxing | No | No | No |
Pin count | 6 | 6 | 6 |
Размер памяти программ, KB | 1 | 1 | 1 |
SRAM, Bytes | 32 | 32 | 32 |
Temp Range Max | 125 | 125 | 125 |
Temp Range Min | -40 | -40 | -40 |
Zero Cross detect | No | No | No |
Серия: ATtiny10 (3)
- Microcontrollers > 8-bit Microcontrollers
