Datasheet Microchip ATtiny20 — Даташит
Производитель | Microchip |
Серия | ATtiny20 |
The high-performance, low-power Microchip 8-bit AVR RISC-based microcontroller combines 2KB ISP flash memory, 128B SRAM, twelve general purpose I/O lines, 16 general purpose working registers, an 8-bit timer/counter with two PWM channels, a 16-bit timer/counter with two PWM channels, internal and external interrupts, an 8-channel 10-bit A/D converter, programmable watchdog timer with internal oscillator, a slave two-wire interface, a master/slave serial peripheral interface, an internal calibrated oscillator, and four software selectable power saving modes
Купить ATtiny20 на РадиоЛоцман.Цены — от 33 до 890 ₽ 47 предложений от 28 поставщиков 8 Bit MCU, AVR Family ATtiny20 Series Microcontrollers, 12 МГц, 2 КБ, 128 Байт, 14 вывод(-ов) | |||
ATTINY20-SSUR Microchip | 33 ₽ | ||
ATTINY20-SSUR Microchip | 34 ₽ | ||
Отладочная плата ATtiny20pin | от 890 ₽ | ||
ATTINY20-CCUR Microchip | по запросу |
ATTINY20-CCU | ATTINY20-CCUR | ATTINY20-MMH | ATTINY20-MMHR | ATTINY20-MMHRA0 | ATTINY20-SSU | ATTINY20-SSUR | ATTINY20-UUR | ATTINY20-XU | ATTINY20-XUR | |
Статус продукта | В производстве (Подходит для новых разработок, но могут существовать и более новые альтернативы) | |||||||||
N | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 |
Корпус | UFBGA | UFBGA | VQFN | VQFN | VQFN | SOIC | SOIC | WLCSP | TSSOP | TSSOP |
Количество выводов | 20 |
Parameters / Models | ATTINY20-CCU | ATTINY20-CCUR | ATTINY20-MMH | ATTINY20-MMHR | ATTINY20-MMHRA0 | ATTINY20-SSU | ATTINY20-SSUR | ATTINY20-UUR | ATTINY20-XU | ATTINY20-XUR |
# of Comparators | 1 | |||||||||
ADC Input | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | |
ADC with Computation | No | No | No | No | No | No | No | No | No | |
ADCC with Computation | No | |||||||||
Angular Timer | No | No | No | No | No | No | No | No | No | No |
Архитектура | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
CPU | 8-bit AVR | |||||||||
CPU Type | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | 8-bit AVR | |
CRC | No | No | No | No | No | No | No | No | No | |
CRC/Scan | No | |||||||||
Class B Hardware | No | No | No | No | No | No | No | No | No | |
High Voltage Capable | No | No | No | No | No | No | No | No | No | No |
I2C | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Internal Oscillator | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Internal Voltage Reference, Bandgap | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
Lead Count | 15 | 15 | 20 | 20 | 14 | 14 | 12 | 14 | 14 | |
Math Accelerator | No | No | No | No | No | No | No | No | No | No |
Max # PWM outputs, including complementary outputs | 3 | |||||||||
Max 16 Bit Digital Timers | 1 | |||||||||
Max 16-Bit Digital Timers | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | |
Max 8 Bit Digital Timers | 1 | |||||||||
Max 8-Bit Digital Timers | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | |
Max A/D Resolution, bits | 10 | |||||||||
Max ADC Resolution, Bits | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | |
Max CPU Speed, МГц | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 | 12 | |
Max PWM outputs, including complementary | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | |
Max. CPU Speed MHz | 12 | |||||||||
Количество компараторов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | |
Рабочий диапазон температур, °C | от -40 до +85 | |||||||||
Operation Voltage Max, В | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | |
Operation Voltage Max.(V) | 5.5 | |||||||||
Operation Voltage Min, В | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | |
Operation Voltage Min.(V) | 1.8 | |||||||||
Package Width | 3x3x0.6mm | 3x3x0.6mm | 3x3x0.85mm | 3x3x0.85mm | .150In(3.90mm) | .150In(3.90mm) | 1.555x1.403x0.538mm | 4.4mm | 4.4mm | |
Peripheral Pin Select, PPS | No | |||||||||
Peripheral Pin Select / Pin Muxing | No | No | No | No | No | No | No | No | No | |
Pin count | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 |
Размер памяти программ, KB | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
RAM, bytes | 128 | |||||||||
SPI | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
SRAM, Bytes | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 | 128 | |
Temp Range Max | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | |
Temp Range Min | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | -40 | |
Temp. Range Max. | 85 | |||||||||
Temp. Range Min. | -40 | |||||||||
Total # of A/D channels | 8 | |||||||||
Windowed Watchdog Timer, WWDT | No | |||||||||
Zero Cross detect | No | No | No | No | No | No | No | No | No | No |
Серия: ATtiny20 (10)
- Microcontrollers > 8-bit Microcontrollers
