Datasheet Linear Technology LT1077AIN8#PBF — Даташит
Серия | LT1077 |
Модель | LT1077AIN8#PBF |
Micropower, Single Supply, Precision Op Amp
Datasheet LT1077
PDF, 309 Кб, Язык: анг., Файл закачен: 4 авг 2017, Страниц: 16
![]() 19 предложений от 12 поставщиков Микросхема: IC OPAMP GP 1 CIRCUIT 8DIP | |||
LT1077AIN8#PBF Analog Devices | 295 ₽ | ||
LT1077AIN8 Linear Technology | 360 ₽ | ||
LT1077AIN8 Analog Devices | 1 341 ₽ | ||
LT1077AIN8 Linear Technology | по запросу |
Корпус | N-8 |
Код корпуса | N |
Индекс корпуса | 05-08-1510 (N8) |
Количество каналов | 1 |
Частота единичного усиления GBW | 0.23 МГц |
Av Min Stable | 1 V/V |
Avol | 60 дБ |
CMRR | 106 дБ |
Cload | 1500 пФ |
Demo Boards | DC417B |
Design Tools | LTspice Model |
Enoise 1/f Corner | 0.7 Hz |
Enoise Density | 27 нВ/rtГц |
Экспортный контроль | нет |
Ibias | 7 нА |
Inoise | 0.065 пА/rtГц |
Inoise 1/f Corner | 95 Hz |
Ios | 0.00000008 мкА |
Iout | 25 мА |
Isupply | 0.048 мА |
LF Enoise | 0.5 µVPP |
Over-the-Top | нет |
PSRR | 118 дБ |
Rail-to-Rail | In to V- |
Rail-to-Rail In | нет |
Rail-to-Rail Out | нет |
SR | 0.08 В/мс |
Shutdown | нет |
Single Supply | да |
Тип | VFB |
VinCM High (from V+) | 1.2 В |
VinCM Low (from V-) | -0.3 В |
Vos | 0.009 мВ |
Vos TC | 0.4 мВ/C |
Vs макс. | 44 В |
Vs мин. | 2.2 В |
- Using the LTC Op Amp Macromodels &mdash AN48PDF, 297 Кб, Файл опубликован: 8 ноя 1991
LTC's op amp macromodels are described in detail, along with the theory behind each model and complete schematics of each topology. Extended modeling topics are discussed, such as phase/frequency response modifications and asymmetric slew rate for JFET op amp models. LTC's macromodels are optimized for accuracy and fast simulation times. Simulation times can be further reduced by using streamlining techniques found throughout AN48.Выписка из документа - Techniques for 92% Efficient LCD Illumination &mdash AN55PDF, 688 Кб, Файл опубликован: 1 авг 1993
This publication details several LCD backlight circuits which feature 92% efficiency. Other benefits include low voltage operation, synchronizing capability, higher output power for color displays, and extended dimming range. Extensive coverage of practical issues includes layout problems, multi-lamp displays, safety and reliability concerns and efficiency and photometric measurements. Also included is a review of circuits which did not work along with appropriate commentary.Выписка из документа - Using the LTC1325 Battery Management IC: &mdash AN64PDF, 385 Кб, Файл опубликован: 2 авг 1996
Application Note 64 details characteristics of various battery types and appropriate charging management schemes. The LTC1325 battery management IC is highlighted along with information for applying it to any type battery. Techniques and circuitry for conditioning, charging and monitoring NiCd, NiMH, Li-Ion and Lead-Acid batteries are presented.Выписка из документа - Linear Technology Magazine Circuit Collection, Volume III &mdash AN67PDF, 1.2 Мб, Файл опубликован: 1 сен 1996
Application Note 67 is a collection of circuits for data conversion, interface and signal processing from the first five years of Linear Technology. This application note includes circuits such as fast video multiplexers for high speed video, an ultraselective bandpass filter circuit with adjustable gain, and a fully differential, 8-channel, 12-bit A/D system. The categories included in this app note are data conversion, interface, filters, instrumentation, video/op amps and miscellaneous circuits.Выписка из документа - A Seven-Nanosecond Comparator for Single Supply Operation &mdash AN72PDF, 882 Кб, Файл опубликован: 1 май 1998
AN72 is an extensive discussion of the causes and cures of problems in very high speed comparator circuits. A separate applications section uses the 7ns LT1394 in V-to-F converters, crystal oscillators, clock skew generators, triggers, sampling configurations and a nanosecond pulse stretcher. Appendices cover related topics.Выписка из документа - Bias Voltage and Current Sense Circuits for Avalanche Photodiodes &mdash AN92PDF, 1.1 Мб, Файл опубликован: 1 ноя 2002
Avalanche photodiodes, used in laser based fiberoptic systems, require high voltage bias and accurate, wide range current monitoring. Bias voltage varies from 15V-90V and current ranges from 100nA to 1mA, a 10,000:1 dynamic range. This publication presents various 5 volt powered circuits which meet these requirements. Appended sections detail specific circuit techniques and cover measurement practice.Выписка из документа
Design Notes
- The LTC1446/LTC1446L: World's First Dual 12-Bit DACs in SO-8 &mdash DN131PDF, 77 Кб, Файл опубликован: 3 июн 1996Выписка из документа
- Micropower, Single Supply Applications: (1) A Self-Biased, Buffered Reference (2) Megaohm Input Impedance Difference Amplifier &mdash DN23PDF, 199 Кб, Файл опубликован: 1 июн 1989Выписка из документа
- A Single Amplifier, Precision High Voltage Instrument Amp &mdash DN25PDF, 71 Кб, Файл опубликован: 1 авг 1989Выписка из документа
- Chopper vs Bipolar Op Amps—An Unbiased Comparison &mdash DN42PDF, 70 Кб, Файл опубликован: 1 дек 1990Выписка из документа
- 3V Operation of Linear Technology Op Amps &mdash DN56PDF, 78 Кб, Файл опубликован: 1 фев 1992Выписка из документа
- 12-Bit Rail-to-Rail Micropower DACs in an SO-8 &mdash DN96PDF, 76 Кб, Файл опубликован: 1 фев 1995Выписка из документа
Статьи
- Infinite Sample-and-Hold Outperforms Many Legacy Sample-and-Hold Amplifiers &mdash LT JournalPDF, 159 Кб, Файл опубликован: 1 ноя 2000Выписка из документа
Серия: LT1077 (8)
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | High Voltage Amplifiers (>12V) | Low Power Amplifiers (Is < 1mA/amp)
LT1077AIN8PBF, LT1077AIN8 PBF
