Datasheet Linear Technology LT1022CN8#PBF — Даташит
Серия | LT1022 |
Модель | LT1022CN8#PBF |
Высокоскоростной прецизионный операционный усилитель с JFET-входом
Datasheet LT1022
PDF, 160 Кб, Язык: анг., Файл закачен: 12 июл 2022, Страниц: 12
High Speed, Precision JFET Input Operational Amplifier
Datasheet LT1022
PDF, 165 Кб, Язык: анг., Файл закачен: 4 авг 2017, Страниц: 12
Купить LT1022CN8#PBF на РадиоЛоцман.Цены — от 67 до 1 116 ₽ 19 предложений от 15 поставщиков High Speed, Precision JFET Input Operational Amplifier | |||
LT1022 LT1022CN8 DIP | 67 ₽ | ||
LT1022CN8#PBF Analog Devices | 209 ₽ | ||
LT1022CN8 Linear Technology | 249 ₽ | ||
LT1022CN8 Linear Technology | 595 ₽ |
- Power Gain Stages for Monolithic Amplifiers &mdash AN18PDF, 2.5 Мб, Файл опубликован: 1 мар 1986
This note presents output state circuits which provide power gain for monolithic amplifiers. The circuits feature voltage gain, current gain, or both. Eleven designs are shown, and performance is summarized. A generalized method for frequency compensation appears in a separate section.Выписка из документа - Composite Amplifiers &mdash AN21PDF, 330 Кб, Файл опубликован: 1 июл 1986
Applications often require an amplifier that has extremely high performance in several areas. For example, high speed and DC precision are often needed. If a single device cannot simultaneously achieve the desired characteristics, a composite amplifier made up of two (or more) devices can be configured to do the job. AN21 shows examples of composite approaches in designs combining speed, precision, low noise and high power.Выписка из документа - Converting Light to Digits: LTC1099 Half Flash 8-Bit A/D Converter Digitizes Photodiode Array &mdash AN33PDF, 703 Кб, Файл опубликован: 2 мар 1989
This application note describes a Linear Technology "Half-Flash" A/D converter, the LTC1099, being connected to a 256 element line scan photodiode array. This technology adapts itself to handheld (i.e., low power) bar code readers, as well as high resolution automated machine inspection applications. - Bridge Circuits &mdash AN43PDF, 3.8 Мб, Файл опубликован: 1 июн 1990
Subtitled "Marrying Gain and Balance," this note covers signal conditioning circuits for various types of bridges. Included are transducer bridges, AC bridges, Wien bridge oscillators, Schottky bridges, and others. Special attention is given to amplifier selection criteria. Appended sections cover strain gauge transducers, understanding distortion measurements, and historical perspectives on bridge readout mechanisms and Wein bridge oscillators.Выписка из документа - Using the LTC Op Amp Macromodels &mdash AN48PDF, 297 Кб, Файл опубликован: 8 ноя 1991
LTC's op amp macromodels are described in detail, along with the theory behind each model and complete schematics of each topology. Extended modeling topics are discussed, such as phase/frequency response modifications and asymmetric slew rate for JFET op amp models. LTC's macromodels are optimized for accuracy and fast simulation times. Simulation times can be further reduced by using streamlining techniques found throughout AN48.Выписка из документа
Design Notes
- Updated Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN140PDF, 74 Кб, Файл опубликован: 1 окт 1996Выписка из документа
- Noise Calculations in Op Amp Circuits &mdash DN15PDF, 224 Кб, Файл опубликован: 1 сен 1988Выписка из документа
- Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN3PDF, 224 Кб, Файл опубликован: 1 окт 1987Выписка из документа
- Operational Amplifier Selection Guide for Optimum Noise Performance &mdash DN6PDF, 137 Кб, Файл опубликован: 1 янв 1988
- A 1mV Offset, Clock-Tunable, Monolithic 5-Pole Lowpass Filter &mdash DN67PDF, 73 Кб, Файл опубликован: 1 фев 1993Выписка из документа
LT1022CN8PBF, LT1022CN8 PBF
