Datasheet Linear Technology LT1210CR#PBF — Даташит
Серия | LT1210 |
Модель | LT1210CR#PBF |
1.1A, 35MHz Current Feedback Amplifier
LT1210 - 1.1A, 35MHz Current Feedback Amplifier
PDF, 1.4 Мб, Версия: B, Файл закачен: 6 авг 2017
Купить LT1210CR#PBF на РадиоЛоцман.Цены — от 512 до 3 386 ₽ 36 предложений от 22 поставщиков LT1210 - 1.1A, 35MHz Current Feedback Amplifier; Package: DD PAK; Pins: 7; Temperature Range: 0°C to 70℃ | |||
LT1210CR#PBF Analog Devices | 512 ₽ | ||
LT1210CR#PBF Analog Devices | 513 ₽ | ||
LT1210CR Analog Devices | по запросу | ||
Корпус | DDPAK-7 |
Код корпуса | R |
Индекс корпуса | 05-08-1462 |
Количество каналов | 1 |
Частота единичного усиления GBW | 66 МГц |
Av Min Stable | 1 V/V |
CMRR | 62 дБ |
Cload | 10000 пФ |
Demo Boards | DC296A |
Design Tools | LTspice Model |
Enoise 1/f Corner | 20 Hz |
Enoise Density | 3 нВ/rtГц |
Экспортный контроль | нет |
Inoise | 2 пА/rtГц |
Inoise 1/f Corner | 300 Hz |
Iout | 2000 мА |
Isupply | 35 мА |
Рабочий диапазон температур | от 0 до 70 °C |
Over-the-Top | нет |
PSRR | 77 дБ |
Rail-to-Rail In | нет |
Rail-to-Rail Out | нет |
SR | 900 В/мс |
Shutdown | да |
Single Supply | нет |
Тип | CFA |
VinCM High (from V+) | 1.5 В |
VinCM Low (from V-) | 1.5 В |
Voh (from V+) | 1.4 В |
Vol (from V-) | 1.5 В |
Vos | 3 мВ |
Vos TC | 10 мВ/C |
Vs макс. | 36 В |
Vs мин. | 8 В |
- Minimizing Switching Regulator Residue in Linear Regulator Outputs &mdash AN101PDF, 358 Кб, Язык: анг., Файл опубликован: 16 июл 2005, Страниц: 12
Application Note 101. Linear regulators are commonly employed to post-regulate switching regulator outputs. Benefits include improved stability, accuracy, transient response and lowered output impedance. Ideally, these performance gains would be accompanied by markedly reduced switching regulator generated ripple and spikes. In practice, all linear regulators encounter some difficulty with ripple and spikes, particularly as frequency rises. This publication explains the causes of linear regulators' dynamic limitations and presents board level techniques for improving ripple and spike rejection. A hardware based ripple/spike simulator is presented, enabling rapid breadboard testing under various conditions. Three appendices review ferrite beads, inductor based filters and probing practice for wideband, sub-millivolt signals.Выписка из документа - Linear Technology Magazine Circuit Collection, Volume V: Data Conversion, Interface and Signal Conditioning Products &mdash AN87PDF, 1.5 Мб, Файл опубликован: 1 ноя 2000
Application Note 87 is the fifth in a series that excerpts useful circuits from Linear Technology magazine. Data conversion, interface and signal conditioning circuits from issue VI:1 (February 1996) through issue VIII:4 (November 1998) are featured. Like its predecessor, AN67, this Application Note includes circuits for high speed video, interface and hot swap circuits, active RC and switched capacitor filter circuitry and a variety of data conversion and instrumentation circuits. All circuits are conveniently indexed by type.Выписка из документа
Design Notes
- Fast Current Feedback Amplifiers Tame Low Impedance Loads &mdash DN132PDF, 91 Кб, Файл опубликован: 1 июл 1996Выписка из документа
Серия: LT1210 (8)
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Voltage Amplifiers (>12V) | Low Noise Amplifiers ( | High Output Current Amplifiers (>100mA) | Current Feedback Amplifiers | High Speed Amplifiers (GBW > 50MHz)
LT1210CRPBF, LT1210CR PBF
