Datasheet Linear Technology LT1228IS8#PBF — Даташит
Серия | LT1228 |
Модель | LT1228IS8#PBF |
100MHz Current Feedback Amplifier with DC Gain Control
Datasheet LT1228
PDF, 681 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 22
Купить LT1228IS8#PBF на РадиоЛоцман.Цены — от 350 до 2 484 ₽ 26 предложений от 16 поставщиков 100MHz Current Feedback Amplifier with DC Gain Control | |||
LT1228IS8#PBF Analog Devices | 350 ₽ | ||
LT1228IS8#TRPBF Linear Technology | 442 ₽ | ||
LT1228IS8#PBF Analog Devices | от 1 030 ₽ | ||
LT1228IS8#TRPBF Analog Devices | по запросу |
Корпус | SO-8 |
Код корпуса | S8 |
Индекс корпуса | 05-08-1610 (S8) |
Av Min Stable | 1 V/V |
CMRR | 69 дБ |
Количество каналов | 1 |
Cload | 2000 пФ |
Demo Boards | DC417B |
Design Tools | LTspice Model |
Enoise Density | 20 нВ/rtГц |
Экспортный контроль | нет |
GBW | 100 МГц |
HD2 | -67 dBc |
HD3 | -60 dBc |
Ibias | 0.4 мкА |
Inoise | 1.4 пА/rtГц |
Iout | 65 мА |
Isupply | 9 мА |
PSRR | 80 дБ |
Rail-to-Rail In | нет |
Rail-to-Rail Out | нет |
SR | 500 В/мс |
Shutdown | нет |
Single Supply | нет |
Ts (0.1%) | 45 нс |
Тип | CFA |
VinCM High (from V+) | 1 В |
VinCM Low (from V-) | 1 В |
Voh (from V+) | 0.8 В |
Vol (from V-) | 0.8 В |
Vos | 0.5 мВ |
Vos TC | 10 мВ/C |
Vs макс. | 36 В |
Vs мин. | 4 В |
- High Speed Amplifier Techniques &mdash AN47PDF, 5.3 Мб, Файл опубликован: 1 авг 1991
This application note, subtitled "A Designer's Companion for Wideband Circuitry," is intended as a reference source for designing with fast amplifiers. Approximately 150 pages and 300 figures cover frequently encountered problems and their possible causes. Circuits include a wide range of amplifiers, filters, oscillators, data converters and signal conditioners. Eleven appended sections discuss related topics including oscilloscopes, probe selection, measurement and equipment considerations, and breadboarding techniques.Выписка из документа - Linear Technology Magazine Circuit Collection, Volume 1 &mdash AN52PDF, 190 Кб, Файл опубликован: 1 янв 1993
This application note consolidates the circuits from the first few years of Linear Technology magazine into one publication. Presented in the note are a variety of circuits ranging from a 50W high efficiency (>90%) switching regulator to steep roll-off filter circuits with low distortion to 12-bit differential temperature measurement systems.Выписка из документа - Video Circuit Collection &mdash AN57PDF, 559 Кб, Файл опубликован: 2 янв 1994
AN57, the Video Circuit Collection, features a variety of video circuits designed at LTC. The LT1204 70MHz multiplexer is featured in a number of circuits which require excellent video isolation from channel to channel. High speed voltage and current feedback amplifiers are highlighted throughout the section on video processing circuits. There is a section on applying Current Feedback Amplifiers (CFAs) and a number of articles taken from the Linear Technology magazine.Выписка из документа - Linear Technology Magazine Circuit Collection, Volume III &mdash AN67PDF, 1.2 Мб, Файл опубликован: 1 сен 1996
Application Note 67 is a collection of circuits for data conversion, interface and signal processing from the first five years of Linear Technology. This application note includes circuits such as fast video multiplexers for high speed video, an ultraselective bandpass filter circuit with adjustable gain, and a fully differential, 8-channel, 12-bit A/D system. The categories included in this app note are data conversion, interface, filters, instrumentation, video/op amps and miscellaneous circuits.Выписка из документа - Signal Sources, Conditioners and Power Circuitry Circuits of the Fall, 2004 &mdash AN98PDF, 886 Кб, Файл опубликован: 19 ноя 2004
Eighteen circuits are presented in this compilation. Signal sources include a voltage controlled current source, an amplitude/frequency stabilized sine wave oscillator, a versatile, 0V to 50V wideband level shift and four sub-nanosecond pulse generators with risetimes as low as 20ps. Five signal conditioners appear; a unique, single positive rail powered amplifier with output to (and below) zero volts, a milliohmmeter, a 0.02% accurate instrumentation amplifier with 120dB CMRR at 125VCM, a 100MHz switch with 5mV control channel feedthrough and a 5V powered, 15ppm linearity quartz stabilized V→F, converter. The power circuits section features a Xenon flashlamp supply, two 5V powered, 0V to 300V DC/DC converters, a fixed 200V output circuit for APD bias, a 100W 0V to 500V, 28V powered converter and a high current paralleling scheme for linear regulators. Two appended sections consider measurement technique and connection practice in sub-nanosecond circuits.Выписка из документа
Design Notes
- Video Circuits Collection &mdash DN57PDF, 79 Кб, Файл опубликован: 1 апр 1992Выписка из документа
- A Broadband Random Noise Generator &mdash DN70PDF, 95 Кб, Файл опубликован: 1 май 1993Выписка из документа
Серия: LT1228 (6)
- LT1228CN8#PBF LT1228CS8#PBF LT1228CS8#TRPBF LT1228IN8#PBF LT1228IS8#PBF LT1228IS8#TRPBF
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Speed Amplifiers (GBW > 50MHz) | Current Feedback Amplifiers | High Voltage Amplifiers (>12V)
- Signal Conditioning > Amplifiers > Video Functions
LT1228IS8PBF, LT1228IS8 PBF
