Datasheet Linear Technology LT1637 — Даташит
Серия | LT1637 |
1.1MHz, 0.4V/us Over-The-Top Micropower, Rail-To-Rail Input and Output Op Amp
Datasheet LT1637
PDF, 366 Кб, Язык: анг., Файл закачен: 1 ноя 2016, Страниц: 16
1.1MHz, 0.4V/µs Over-The-Top Micropower, Rail-To-Rail Input and Output Op Amp
Купить LT1637 на РадиоЛоцман.Цены — от 108 до 974 ₽ 33 предложений от 23 поставщиков 1.1MHz, 0.4V/??s Over-The-Top Micropower, Rail-To-Rail Input and Output Op Amp | |||
LT1637CN8 Analog Devices | 108 ₽ | ||
LT1637CMS8 | от 110 ₽ | ||
LT1637CN8 Linear Technology | 348 ₽ | ||
LT1637CDD#TR Linear Technology | по запросу |
Parameters / Models | LT1637CDD#PBF | LT1637CDD#TRPBF | LT1637CMS8#PBF | LT1637CMS8#TRPBF | LT1637CN8#PBF | LT1637CS8#PBF | LT1637CS8#TRPBF | LT1637HS8#PBF | LT1637HS8#TRPBF | LT1637IDD#PBF | LT1637IDD#TRPBF | LT1637IMS8#PBF | LT1637IMS8#TRPBF | LT1637IN8#PBF | LT1637IS8#PBF | LT1637IS8#TRPBF | LT1637MPS8 | LT1637MPS8#PBF | LT1637MPS8#TR | LT1637MPS8#TRPBF |
Av Min Stable, V/V | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Avol, дБ | 58 | 58 | 58 | 58 | 58 | 58 | 58 | 58 | 58 | 58 | 58 | 58 | 58 | 58 | 58 | 58 | 58 | 58 | 58 | 58 |
CMRR, дБ | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Cload, пФ | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 |
Demo Boards | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B | DC593A,DC417B |
Design Tools | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File |
Enoise 1/f Corner, Hz | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Enoise Density, нВ/rtГц | 27 | 27 | 27 | 27 | 27 | 27 | 27 | 27 | 27 | 27 | 27 | 27 | 27 | 27 | 27 | 27 | 27 | 27 | 27 | 27 |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
GBW, МГц | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Ibias, нА | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 20 |
Inoise, пА/rtГц | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 | 0.08 |
Inoise 1/f Corner, Hz | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 | 9 |
Ios, мкА | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 | 0.0004 |
Iout, мА | 22 | 22 | 22 | 22 | 22 | 22 | 22 | 22 | 22 | 22 | 22 | 22 | 22 | 22 | 22 | 22 | 22 | 22 | 22 | 22 |
Isupply, мА | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 | 0.19 |
LF Enoise, µVPP | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 | 0.6 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
Over-the-Top | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
PSRR, дБ | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 | 98 |
Rail-to-Rail | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both |
Rail-to-Rail In | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Rail-to-Rail Out | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
SR, В/мс | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 | 0.35 |
Shutdown | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Single Supply | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Ts (0.1%), нс | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 | 9000 |
Тип | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB |
VinCM High (from V+), В | -44 | -44 | -44 | -44 | -44 | -44 | -44 | -44 | -44 | -44 | -44 | -44 | -44 | -44 | -44 | -44 | -44 | -44 | -44 | -44 |
Voh (from V+), В | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 |
Vol (from V-), В | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 |
Vos, мВ | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 |
Vos TC, мВ/C | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Vs макс., В | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 | 44 |
Vs мин., В | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
LT1637CDD#PBF | LT1637CDD#TRPBF | LT1637CMS8#PBF | LT1637CMS8#TRPBF | LT1637CN8#PBF | LT1637CS8#PBF | LT1637CS8#TRPBF | LT1637HS8#PBF | LT1637HS8#TRPBF | LT1637IDD#PBF | LT1637IDD#TRPBF | LT1637IMS8#PBF | LT1637IMS8#TRPBF | LT1637IN8#PBF | LT1637IS8#PBF | LT1637IS8#TRPBF | LT1637MPS8 | LT1637MPS8#PBF | LT1637MPS8#TR | LT1637MPS8#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Не совместим | Совместим | Не совместим | Совместим |
Серия: LT1637 (20)
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | Low Power Amplifiers (Is < 1mA/amp) | High Voltage Amplifiers (>12V) | Rail-to-Rail Amplifiers
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Amplifiers
