Datasheet Linear Technology LT1678IS8#PBF — Даташит
Серия | LT1678 |
Модель | LT1678IS8#PBF |
Dual/Quad Low Noise, Rail-to-Rail, Precision Op Amps
Datasheet LT1678, LT1679
PDF, 300 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 16
Купить LT1678IS8#PBF на РадиоЛоцман.Цены — от 224 до 1 331 ₽ 27 предложений от 20 поставщиков Op Amp Dual Low Noise Amplifier R-R I/O ±18V/36V Automotive 8-Pin SOIC N Tube | |||
LT1678IS8#PBF Analog Devices | 224 ₽ | ||
LT1678IS8 Analog Devices | 241 ₽ | ||
LT1678IS8#PBF Analog Devices | от 373 ₽ | ||
LT1678IS8#TR | по запросу |
Корпус | SO-8 |
Код корпуса | S8 |
Индекс корпуса | 05-08-1610 (S8) |
Количество каналов | 2 |
Частота единичного усиления GBW | 20 МГц |
Av Min Stable | 1 V/V |
Avol | 70 дБ |
CMRR | 120 дБ |
Cload | 500 пФ |
Design Tools | LTspice File |
Enoise 1/f Corner | 10 Hz |
Enoise Density | 3.9 нВ/rtГц |
Экспортный контроль | нет |
Ibias | 2 нА |
Inoise | 0.3 пА/rtГц |
Inoise 1/f Corner | 90 Hz |
Ios | 0.004 мкА |
Iout | 22 мА |
Isupply | 2 мА |
LF Enoise | 0.090 µVPP |
Over-the-Top | нет |
PSRR | 125 дБ |
Rail-to-Rail | Both |
Rail-to-Rail In | да |
Rail-to-Rail Out | да |
SR | 6 В/мс |
Shutdown | нет |
Single Supply | да |
Ts (0.1%) | 1400 нс |
Тип | VFB |
Voh (from V+) | .075 В |
Vol (from V-) | .08 В |
Vos | 0.035 мВ |
Vos TC | 0.4 мВ/C |
Vs макс. | 36 В |
Vs мин. | 3 В |
- Delta Sigma ADC Bridge Measurement Techniques &mdash AN96PDF, 232 Кб, Файл опубликован: 17 янв 2005
AN96 features several applications that demonstrate how to take full advantage of Linear Technology's delta sigma ADCs when interfacing to sensors. In many cases, signal conditioning can be greatly simplified or eliminated completely. This note explains where it is appropriate to use amplifiers and how to optimize amplifier gain. Also included are discussions on measuring effective number of bits (ENOB) and the relationship to instrument performance, frequency response of delta sigma ADCs, and test techniques. C source code for all of the applications is included to aid firmware development.Выписка из документа
Серия: LT1678 (4)
- LT1678CS8#PBF LT1678CS8#TRPBF LT1678IS8#PBF LT1678IS8#TRPBF
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Low Noise Amplifiers ( | High Voltage Amplifiers (>12V) | Rail-to-Rail Amplifiers | Precision Amplifiers (Vos
LT1678IS8PBF, LT1678IS8 PBF
