Datasheet Linear Technology LT1815 — Даташит
Серия | LT1815 |
Single 220MHz, 1500V/µs Operational Amplifiers with Programmable Supply Current
Datasheet LT1815, LT1816, LT1817
PDF, 556 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 20
Quad 220MHz, 1500V/µs Operational Amplifiers with Programmable Supply Current
Купить LT1815 на РадиоЛоцман.Цены — от 74 до 330 ₽ 16 предложений от 16 поставщиков LT1815 - Single 220MHz, 1500V/µs Operational Amplifiers with Programmable Supply Current | |||
LT1815CS8 Analog Devices | 74 ₽ | ||
LT1815CS8 Linear Technology | 85 ₽ | ||
LT1815IS5 | по запросу | ||
LT1815CS6 | по запросу |
Parameters / Models | LT1815CS5#PBF | LT1815CS5#TRMPBF | LT1815CS5#TRPBF | LT1815CS6#PBF | LT1815CS6#TRMPBF | LT1815CS6#TRPBF | LT1815CS8#PBF | LT1815CS8#TRPBF | LT1815IS5#PBF | LT1815IS5#TRMPBF | LT1815IS5#TRPBF | LT1815IS6#PBF | LT1815IS6#TRMPBF | LT1815IS6#TRPBF | LT1815IS8#PBF | LT1815IS8#TRPBF |
Av Min Stable, V/V | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Avol, дБ | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
CMRR, дБ | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Cload, пФ | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Demo Boards | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Enoise 1/f Corner, Hz | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 |
Enoise Density, нВ/rtГц | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
GBW, МГц | 220 | 220 | 220 | 220 | 220 | 220 | 220 | 220 | 220 | 220 | 220 | 220 | 220 | 220 | 220 | 220 |
Ibias, нА | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 | 2000 |
Inoise, пА/rtГц | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 |
Inoise 1/f Corner, Hz | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 |
Ios, мкА | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 | 0.06 |
Iout, мА | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 |
Isupply, мА | 6.5 | 6.5 | 6.5 | 6.5 | 6.5 | 6.5 | 6.5 | 6.5 | 6.5 | 6.5 | 6.5 | 6.5 | 6.5 | 6.5 | 6.5 | 6.5 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Over-the-Top | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
PSRR, дБ | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 | 97 |
Rail-to-Rail In | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Rail-to-Rail Out | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
SR, В/мс | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 | 1500 |
Shutdown | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Single Supply | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ts (0.1%), нс | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 | 15 |
Тип | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB |
VinCM High (from V+), В | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
VinCM Low (from V-), В | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
Voh (from V+), В | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 |
Vol (from V-), В | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 | 0.9 |
Vos, мВ | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 |
Vos TC, мВ/C | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Vs макс., В | 12.6 | 12.6 | 12.6 | 12.6 | 12.6 | 12.6 | 12.6 | 12.6 | 12.6 | 12.6 | 12.6 | 12.6 | 12.6 | 12.6 | 12.6 | 12.6 |
Vs мин., В | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
LT1815CS5#PBF | LT1815CS5#TRMPBF | LT1815CS5#TRPBF | LT1815CS6#PBF | LT1815CS6#TRMPBF | LT1815CS6#TRPBF | LT1815CS8#PBF | LT1815CS8#TRPBF | LT1815IS5#PBF | LT1815IS5#TRMPBF | LT1815IS5#TRPBF | LT1815IS6#PBF | LT1815IS6#TRMPBF | LT1815IS6#TRPBF | LT1815IS8#PBF | LT1815IS8#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Design Notes
- A Complete Compact APD Bias Solution for a 10Gbits/s GPON System &mdash DN447PDF, 110 Кб, Файл опубликован: 14 июл 2008Выписка из документа
Статьи
- LT1815: 220MHz, 1500V/µs Amplifier Saves Space and Power &mdash LT JournalPDF, 173 Кб, Файл опубликован: 1 май 2001Выписка из документа
Серия: LT1815 (16)
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Low Noise Amplifiers ( | High Speed Amplifiers (GBW > 50MHz) | High Voltage Amplifiers (>12V)
