Datasheet Linear Technology LT6010 — Даташит
Серия | LT6010 |
135µA, 14nV/rtHz, Rail-to-Rail Output Precision Op Amp with Shutdown
Datasheet LT6010
PDF, 304 Кб, Язык: анг., Файл закачен: 6 авг 2017, Страниц: 16
135µA, 14nV/√Hz, Rail-to-Rail Output Precision Op Amp with Shutdown
Купить LT6010 на РадиоЛоцман.Цены — от 89 до 598 ₽ 29 предложений от 23 поставщиков Патроны плавких предохранителей ACS 600V Class T 100A 2 Pole | |||
LT6010CS8 Analog Devices | 89 ₽ | ||
LT6010CS8 Analog Devices | от 90 ₽ | ||
LT6010IDD#PBF Analog Devices | по запросу | ||
LT6010CDD#TRPBF Linear Technology | по запросу |
Parameters / Models | LT6010ACDD#PBF | LT6010ACDD#TRPBF | LT6010ACS8#PBF | LT6010ACS8#TRPBF | LT6010AIDD#PBF | LT6010AIDD#TRPBF | LT6010AIS8#PBF | LT6010AIS8#TRPBF | LT6010CDD#PBF | LT6010CDD#TRPBF | LT6010CS8#PBF | LT6010CS8#TRPBF | LT6010IDD#PBF | LT6010IDD#TRPBF | LT6010IS8#PBF | LT6010IS8#TRPBF |
Av Min Stable, V/V | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Avol, дБ | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 | 66 |
CMRR, дБ | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Cload, пФ | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 | 500 |
Demo Boards | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Enoise 1/f Corner, Hz | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Enoise Density, нВ/rtГц | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 | 14 |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
GBW, МГц | 0.33 | 0.33 | 0.33 | 0.33 | 0.33 | 0.33 | 0.33 | 0.33 | 0.33 | 0.33 | 0.33 | 0.33 | 0.33 | 0.33 | 0.33 | 0.33 |
Ibias, нА | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 |
Inoise, пА/rtГц | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 | 0.1 |
Inoise 1/f Corner, Hz | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Ios, мкА | 0.00002 | 0.00002 | 0.00002 | 0.00002 | 0.00002 | 0.00002 | 0.00002 | 0.00002 | 0.00002 | 0.00002 | 0.00002 | 0.00002 | 0.00002 | 0.00002 | 0.00002 | 0.00002 |
Iout, мА | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 | 5 |
Isupply, мА | 0.135 | 0.135 | 0.135 | 0.135 | 0.135 | 0.135 | 0.135 | 0.135 | 0.135 | 0.135 | 0.135 | 0.135 | 0.135 | 0.135 | 0.135 | 0.135 |
LF Enoise, µVPP | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Over-the-Top | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
PSRR, дБ | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 | 135 |
Rail-to-Rail | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output | Output |
Rail-to-Rail In | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Rail-to-Rail Out | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
SR, В/мс | 0.09 | 0.09 | 0.09 | 0.09 | 0.09 | 0.09 | 0.09 | 0.09 | 0.09 | 0.09 | 0.09 | 0.09 | 0.09 | 0.09 | 0.09 | 0.09 |
Shutdown | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Single Supply | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Ts (0.1%), нс | 45000 | 45000 | 45000 | 45000 | 45000 | 45000 | 45000 | 45000 | 45000 | 45000 | 45000 | 45000 | 45000 | 45000 | 45000 | 45000 |
Тип | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB |
VinCM High (from V+), В | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
VinCM Low (from V-), В | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 | 0.7 |
Voh (from V+), В | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 | 0.035 |
Vol (from V-), В | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 | 0.04 |
Vos, мВ | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 |
Vos TC, мВ/C | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 |
Vs макс., В | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 | 40 |
Vs мин., В | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
LT6010ACDD#PBF | LT6010ACDD#TRPBF | LT6010ACS8#PBF | LT6010ACS8#TRPBF | LT6010AIDD#PBF | LT6010AIDD#TRPBF | LT6010AIS8#PBF | LT6010AIS8#TRPBF | LT6010CDD#PBF | LT6010CDD#TRPBF | LT6010CS8#PBF | LT6010CS8#TRPBF | LT6010IDD#PBF | LT6010IDD#TRPBF | LT6010IS8#PBF | LT6010IS8#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: LT6010 (16)
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > High Voltage Amplifiers (>12V) | Precision Amplifiers (Vos | Low Power Amplifiers (Is < 1mA/amp) | Low Bias Current Amplifiers (Ib < 100pA) | Rail-to-Rail Amplifiers
