Datasheet Linear Technology LTC2050 — Даташит
Серия | LTC2050 |
Zero-Drift Operational Amplifiers in SOT-23
LTC2050: Zero-Drift Operational Amplifiers in SOT-23 Data Sheet
PDF, 735 Кб, Файл закачен: 20 авг 2017
Купить LTC2050 на РадиоЛоцман.Цены — от 33 до 752 ₽ 31 предложений от 24 поставщиков ОУх1 Uпит=2.7...±5.5В; Iпот.=0.8мА; Uсм=3мкВ; 2В/мкС, f=3МГц, Uш=50нВ/Гц, 30нВ/°C макс. дрифт. | |||
LTC2050HVCS8 Linear Technology | 33 ₽ | ||
LTC2050HVCS8 Linear Technology | 87 ₽ | ||
LTC2050HS6 TRPBF | по запросу | ||
LTC2050IS6 | по запросу |
Parameters / Models | LTC2050CS5#PBF | LTC2050CS5#TRMPBF | LTC2050CS5#TRPBF | LTC2050CS6#PBF | LTC2050CS6#TRMPBF | LTC2050CS6#TRPBF | LTC2050CS8#PBF | LTC2050CS8#TRPBF | LTC2050HS5#PBF | LTC2050HS5#TRMPBF | LTC2050HS5#TRPBF | LTC2050HS6#PBF | LTC2050HS6#TRMPBF | LTC2050HS6#TRPBF | LTC2050IS5#PBF | LTC2050IS5#TRMPBF | LTC2050IS5#TRPBF | LTC2050IS6#PBF | LTC2050IS6#TRMPBF | LTC2050IS6#TRPBF | LTC2050IS8#PBF | LTC2050IS8#TRPBF |
Av Min Stable, V/V | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Avol, дБ | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 |
CMRR, дБ | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 |
Количество каналов | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Cload, пФ | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 |
Demo Boards | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B | DC417B |
Design Tools | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File | LTspice File |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
GBW, МГц | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
Ibias, нА | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 |
Inoise, пА/rtГц | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 | 0.003 |
Ios, мкА | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 | 0.0003 |
Iout, мА | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Isupply, мА | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
LF Enoise, µVPP | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Over-the-Top | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
PSRR, дБ | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 | 130 |
Rail-to-Rail | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output | In to V-,Output |
Rail-to-Rail In | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Rail-to-Rail Out | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
SR, В/мс | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Shutdown | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Single Supply | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Ts (0.1%), нс | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 |
Тип | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD | ZD |
VinCM High (from V+), В | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 | 1.3 |
Voh (from V+), В | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 | 0.02 |
Vol (from V-), В | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 | 0.001 |
Vos, мВ | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 | 0.0005 |
Vos TC, мВ/C | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 |
Vs макс., В | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
Vs мин., В | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
LTC2050CS5#PBF | LTC2050CS5#TRMPBF | LTC2050CS5#TRPBF | LTC2050CS6#PBF | LTC2050CS6#TRMPBF | LTC2050CS6#TRPBF | LTC2050CS8#PBF | LTC2050CS8#TRPBF | LTC2050HS5#PBF | LTC2050HS5#TRMPBF | LTC2050HS5#TRPBF | LTC2050HS6#PBF | LTC2050HS6#TRMPBF | LTC2050HS6#TRPBF | LTC2050IS5#PBF | LTC2050IS5#TRMPBF | LTC2050IS5#TRPBF | LTC2050IS6#PBF | LTC2050IS6#TRMPBF | LTC2050IS6#TRPBF | LTC2050IS8#PBF | LTC2050IS8#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Design Notes
- Op Amp Selection Guide for Optimum Noise Performance &mdash DN355PDF, 92 Кб, Файл опубликован: 7 янв 2005Выписка из документа
Статьи
- LTC2050, Zero-Drift Operational Amplifier in SOT-23 Package Minimizes Board Area without Compromising Specs &mdash LT JournalPDF, 169 Кб, Файл опубликован: 1 фев 2000Выписка из документа
- Zero-Drift Operational Amplifier Family in Small-Footprint Packages Features 3µV Maximum DC Offset and30nV/°C Maximum Drift &mdash LT JournalPDF, 186 Кб, Файл опубликован: 1 ноя 2000Выписка из документа
Серия: LTC2050 (22)
- LTC2050CS5#PBF LTC2050CS5#TRMPBF LTC2050CS5#TRPBF LTC2050CS6#PBF LTC2050CS6#TRMPBF LTC2050CS6#TRPBF LTC2050CS8#PBF LTC2050CS8#TRPBF LTC2050HS5#PBF LTC2050HS5#TRMPBF LTC2050HS5#TRPBF LTC2050HS6#PBF LTC2050HS6#TRMPBF LTC2050HS6#TRPBF LTC2050IS5#PBF LTC2050IS5#TRMPBF LTC2050IS5#TRPBF LTC2050IS6#PBF LTC2050IS6#TRMPBF LTC2050IS6#TRPBF LTC2050IS8#PBF LTC2050IS8#TRPBF
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | Zero-Drift Amplifiers | Low Power Amplifiers (Is < 1mA/amp) | Low Bias Current Amplifiers (Ib < 100pA) | Rail-to-Rail Amplifiers
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Amplifiers
