Datasheet Linear Technology LTC6247 — Даташит
Серия | LTC6247 |
180MHz, 1mA Power Efficient Dual Rail-to-Rail I/O Op Amps
LTC6246/LTC6247/LTC6248 - 180MHz, 1mA Power Efficient Rail-to-Rail I/O Op Amps
PDF, 724 Кб, Версия: B, Файл закачен: 6 авг 2017
Купить LTC6247 на РадиоЛоцман.Цены — от 166 до 946 ₽ 32 предложений от 22 поставщиков LINEAR TECHNOLOGY LTC6247IKC#TRMPBF Operational Amplifier, Dual, 2 Amplifier, 180MHz, 90V/µs, 2.5V to 5.25V, DFN, 8Pins | |||
LTC6247CDC#TRPBF Analog Devices | 166 ₽ | ||
LTC6247CMS#PBF Linear Technology | 208 ₽ | ||
LTC6247CKC#TRMPBF Linear Technology | по запросу | ||
LTC6247CKC#TRPBF Linear Technology | по запросу |
Parameters / Models | LTC6247CDC#PBF | LTC6247CDC#TRMPBF | LTC6247CDC#TRPBF | LTC6247CKC#PBF | LTC6247CMS#PBF | LTC6247CMS#TRPBF | LTC6247CMS8#PBF | LTC6247CMS8#TRPBF | LTC6247CTS8#PBF | LTC6247CTS8#TRMPBF | LTC6247CTS8#TRPBF | LTC6247HTS8#PBF | LTC6247HTS8#TRMPBF | LTC6247HTS8#TRPBF | LTC6247IDC#PBF | LTC6247IDC#TRMPBF | LTC6247IDC#TRPBF | LTC6247IKC#PBF | LTC6247IMS#PBF | LTC6247IMS#TRPBF | LTC6247IMS8#PBF | LTC6247IMS8#TRPBF | LTC6247ITS8#PBF | LTC6247ITS8#TRMPBF | LTC6247ITS8#TRPBF |
Av Min Stable, V/V | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Avol, дБ | 33 | 33 | 33 | 45 | 33 | 33 | 33 | 33 | 33 | 33 | 33 | 33 | 33 | 33 | 33 | 33 | 33 | 45 | 33 | 33 | 33 | 33 | 33 | 33 | 33 |
Avol dB, дБ | 33 | 33 | |||||||||||||||||||||||
CMRR, дБ | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 | 110 |
Cdiff, пФ | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Количество каналов | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Enoise 1/f Corner, Hz | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 | 300 |
Enoise Density, нВ/rtГц | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 | 4.2 |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
GBW, МГц | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 | 180 |
Ibias, нА | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 | 30 |
Inoise, пА/rtГц | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Inoise 1/f Corner, Hz | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 | 1000 |
Ios, мкА | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 |
Iout, мА | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 | 35 |
Isupply, мА | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 | 0.95 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 |
Over-the-Top | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
PSRR, дБ | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 | 73 |
Rail-to-Rail | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both | Both |
Rail-to-Rail In | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Rail-to-Rail Out | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
SR, В/мс | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 |
Shutdown | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Single Supply | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да | да |
Ts (0.1%), нс | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 | 74 |
Тип | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB | VFB |
Voh (from V+), В | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 | 0.070 |
Vol (from V-), В | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 |
Vos, мВ | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 | 0.05 |
Vos TC, мВ/C | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Vs макс., В | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 | 5.25 |
Vs мин., В | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
LTC6247CDC#PBF | LTC6247CDC#TRMPBF | LTC6247CDC#TRPBF | LTC6247CKC#PBF | LTC6247CMS#PBF | LTC6247CMS#TRPBF | LTC6247CMS8#PBF | LTC6247CMS8#TRPBF | LTC6247CTS8#PBF | LTC6247CTS8#TRMPBF | LTC6247CTS8#TRPBF | LTC6247HTS8#PBF | LTC6247HTS8#TRMPBF | LTC6247HTS8#TRPBF | LTC6247IDC#PBF | LTC6247IDC#TRMPBF | LTC6247IDC#TRPBF | LTC6247IKC#PBF | LTC6247IMS#PBF | LTC6247IMS#TRPBF | LTC6247IMS8#PBF | LTC6247IMS8#TRPBF | LTC6247ITS8#PBF | LTC6247ITS8#TRMPBF | LTC6247ITS8#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
Серия: LTC6247 (25)
- LTC6247CDC#PBF LTC6247CDC#TRMPBF LTC6247CDC#TRPBF LTC6247CKC#PBF LTC6247CMS#PBF LTC6247CMS#TRPBF LTC6247CMS8#PBF LTC6247CMS8#TRPBF LTC6247CTS8#PBF LTC6247CTS8#TRMPBF LTC6247CTS8#TRPBF LTC6247HTS8#PBF LTC6247HTS8#TRMPBF LTC6247HTS8#TRPBF LTC6247IDC#PBF LTC6247IDC#TRMPBF LTC6247IDC#TRPBF LTC6247IKC#PBF LTC6247IMS#PBF LTC6247IMS#TRPBF LTC6247IMS8#PBF LTC6247IMS8#TRPBF LTC6247ITS8#PBF LTC6247ITS8#TRMPBF LTC6247ITS8#TRPBF
- Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | High Speed Amplifiers (GBW > 50MHz) | Low Noise Amplifiers ( | Low Power Amplifiers (Is < 1mA/amp) | Rail-to-Rail Amplifiers
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Amplifiers
