Радиолоцман Электроника en
расширенный поиск +
Datasheet Linear Technology LTC2057
Производитель:Linear Technology
Серия:LTC2057
High Voltage, Low Noise Zero-Drift Operational Amplifier
  • Скачать » Datasheet, PDF, 1.6 Мб
    LTC2057/LTC2057HV - High Voltage, Low Noise Zero-Drift Operational Amplifier
    Выписка из документа ↓
    LTC2057/LTC2057HV
    Description Features Supply Voltage Range n 4.75V to 36V (LTC2057) n 4.75V to 60V (LTC2057HV)
    n Offset Voltage: 4ОјV (Maximum)
    n Offset Voltage Drift: 0.015ОјV/В°C
    (Maximum, –40°C to 125°C)
    n Input Noise Voltage n 200nVP-P, DC to 10Hz (Typ) n 11nV/в€љHz, 1kHz (Typ)
    n Input Common Mode Range: V– – 0.1V to V+ – 1.5V
    n Rail-to-Rail Output
    n Unity Gain Stable
    n Gain Bandwidth Product: 1.5MHz (Typ)
    n Slew Rate: 0.45V/Ојs (Typ)
    n A
    VOL: 150dB (Typ)
    n PSRR: 160dB (Typ)
    n CMRR: 150dB (Typ)
    n Shutdown Mode
    n Applications n n n n n n n n The LTCВ®2057 is a high voltage, low noise, zero-drift operational amplifier that offers precision DC performance
    over a wide supply range of 4.75V to 36V or 4.75V to
    60V for the LTC2057HV. Offset voltage and 1/f noise are
    suppressed, allowing this amplifier to achieve a maximum
    offset voltage of 4μV and a DC to 10Hz input noise voltage of 200nVP-P (typ). The LTC2057’s self-calibrating ...
    LTC2057 на РадиоЛоцман.Цены — от 155 до 690 руб.
    IC OPAMP ZERO-DRIFT 1.5MHZ 8DFN
    Цена LTC2057
    ПоставщикПроизводительНаименованиеЦена
    ЭлитанLinear TechnologyLTC2057IMS8155 руб.
    5 элементLinear TechnologyLTC2057IDD#PBFот 198 руб.
    МосЧипLinear TechnologyLTC2057HVIMS8#PBFпо запросу
    КремнийLTC2057HVIS8 SO8по запросу
    TradeElectronicsLinear TechnologyLTC2057HDD#TRPBFпо запросу
    Все 13 предложений от 11 поставщиков »
 LTC2057HDD#PBFLTC2057HDD#TRPBFLTC2057HMS#PBFLTC2057HMS#TRPBFLTC2057HMS8#PBFLTC2057HMS8#TRPBFLTC2057HS8#PBFLTC2057HS8#TRPBFLTC2057IDD#PBFLTC2057IDD#TRPBFLTC2057IMS#PBFLTC2057IMS#TRPBFLTC2057IMS8#PBFLTC2057IMS8#TRPBFLTC2057IS8#PBFLTC2057IS8#TRPBF
Av Min Stable, V/V1111111111111111
CMRR, dB150150150150150150150150150150150150150150150150
Cdiff, pF3333333333333333
Количество каналов1111111111111111
Demo BoardsDC417BDC417BDC417BDC417BDC417BDC417BDC417BDC417BDC417BDC417BDC417BDC417BDC417BDC417BDC417BDC417B
Design ToolsLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice Model
Enoise Density, nV/rtHz11111111111111111111111111111111
Экспортный контроль, yes/nonononononononononononononononono
GBW, MHz1.51.51.51.51.51.51.51.51.51.51.51.51.51.51.51.5
Ibias, nA0.030.030.030.030.030.030.030.030.030.030.030.030.030.030.030.03
Inoise, pA/rtHz0.170.170.170.170.170.170.170.170.170.170.170.170.170.170.170.17
Ios, ВµA0.000060.000060.000060.000060.000060.000060.000060.000060.000060.000060.000060.000060.000060.000060.000060.00006
Iout, mA26262626262626262626262626262626
Isupply, mA0.80.80.80.80.80.80.80.80.80.80.80.80.80.80.80.8
LF Enoise, ВµVPP0.20.20.20.20.20.20.20.20.20.20.20.20.20.20.20.2
Рабочий диапазон температур, °Cот -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85
Over-the-Top, yes/nonononononononononononononononono
PSRR, dB160160160160160160160160160160160160160160160160
Rail-to-RailIn to V-,OutputIn to V-,OutputIn to V-,OutputIn to V-,OutputIn to V-,OutputIn to V-,OutputIn to V-,OutputIn to V-,OutputIn to V-,OutputIn to V-,OutputIn to V-,OutputIn to V-,OutputIn to V-,OutputIn to V-,OutputIn to V-,OutputIn to V-,Output
Rail-to-Rail In, yes/nonononononononononononononononono
Rail-to-Rail Out, yes/noyesyesyesyesyesyesyesyesyesyesyesyesyesyesyesyes
SR, V/Вµs1.21.21.21.21.21.21.21.21.21.21.21.21.21.21.21.2
Shutdown, yes/noyesyesyesyesyesyesyesyesyesyesyesyesyesyesyesyes
Single Supply, yes/noyesyesyesyesyesyesyesyesyesyesyesyesyesyesyesyes
ТипZDZDZDZDZDZDZDZDZDZDZDZDZDZDZDZD
VinCM High (from V+), V1.51.51.51.51.51.51.51.51.51.51.51.51.51.51.51.5
Voh (from V+), V0.00020.00020.00020.00020.00020.00020.00020.00020.00020.00020.00020.00020.00020.00020.00020.0002
Vol (from V-), V0.00020.00020.00020.00020.00020.00020.00020.00020.00020.00020.00020.00020.00020.00020.00020.0002
Vos, mV0.00050.00050.00050.00050.00050.00050.00050.00050.00050.00050.00050.00050.00050.00050.00050.0005
Vos TC, ВµV/C0.0150.0150.0150.0150.0150.0150.0150.0150.0150.0150.0150.0150.0150.0150.0150.015
Vs Max, V36363636363636363636363636363636
Vs Min, V4.754.754.754.754.754.754.754.754.754.754.754.754.754.754.754.75
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
  • Signal Conditioning > Amplifiers > Operational Amplifiers (Op Amps) > Precision Amplifiers (Vos | Zero-Drift Amplifiers | Low Power Amplifiers (Is < 1mA/amp) | Low Bias Current Amplifiers (Ib < 100pA) | High Voltage Amplifiers (>12V) | Rail-to-Rail Amplifiers
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Amplifiers
На английском языке: Datasheet Linear Technology LTC2057
При перепечатке материалов с сайта прямая ссылка на РадиоЛоцман обязательна.
Срезы ↓
Датчики влажности и температуры ДВТ-03
Цена: от 3 168 руб.
Доставка: Россия и страны СНГ
DIY настольный 3D принтер
Цена: 163 $ (9500 руб.)
Промо-акция, последняя скидка
Очки с подсветкой и сменными окулярами
Цена: от 8 $ (477 руб.)
Бесплатная доставка: Весь мир
радиолоцман вконтакте радиолоцман одноклассники радиолоцман facebook радиолоцман twitter радиолоцман google плюс
