Datasheet Linear Technology LT6700-2 — Даташит
СерияLT6700-2
Маломощный, низковольтный, двойной компаратор с опорным напряжением 400 мВ
Datasheet LT6700, LT6700HV
PDF, 461 Кб, Язык: анг., Файл закачен: 7 авг 2017, Страниц: 20
Micropower, Low Voltage, Dual Comparator with 400mV Reference
Micropower, Low Voltage, SOT-23, Dual Comparator with 400mV Reference
LT6700-2по запросу
LT6700CDCB-2#PBFLT6700CDCB-2#TRMPBFLT6700CDCB-2#TRPBFLT6700CS6-2#PBFLT6700CS6-2#TRMPBFLT6700CS6-2#TRPBFLT6700HDCB-2#PBFLT6700HDCB-2#TRMPBFLT6700HDCB-2#TRPBFLT6700HS6-2#PBFLT6700HS6-2#TRMPBFLT6700HS6-2#TRPBFLT6700IDCB-2#PBFLT6700IDCB-2#TRMPBFLT6700IDCB-2#TRPBFLT6700IS6-2#PBFLT6700IS6-2#TRMPBFLT6700IS6-2#TRPBFLT6700MPDCB-2#PBFLT6700MPDCB-2#TRMPBFLT6700MPDCB-2#TRPBFLT6700MPS6-2#PBFLT6700MPS6-2#TRMPBFLT6700MPS6-2#TRPBF
N123456789101112131415161718192021222324
Корпус2x3 DFN-6
Габаритный чертеж корпуса
2x3 DFN-6
2x3 DFN-6
SOT-23
SOT-23
SOT-23
2x3 DFN-6
2x3 DFN-6
2x3 DFN-6
SOT-23
SOT-23
SOT-23
2x3 DFN-6
2x3 DFN-6
2x3 DFN-6
SOT-23
SOT-23
SOT-23
2x3 DFN-6
2x3 DFN-6
2x3 DFN-6
SOT-23
SOT-23
SOT-23
Код корпусаDCBDCBDCBS6S6S6DCBDCBDCBS6S6S6DCBDCBDCBS6S6S6DCBDCBDCBS6S6S6
Индекс корпуса05-08-171505-08-171505-08-171505-08-163605-08-163605-08-163605-08-171505-08-171505-08-171505-08-163605-08-163605-08-163605-08-171505-08-171505-08-171505-08-163605-08-163605-08-163605-08-171505-08-171505-08-171505-08-163605-08-163605-08-1636
Количество выводов666666666666666666666666
Parameters / ModelsLT6700CDCB-2#PBFLT6700CDCB-2#TRMPBFLT6700CDCB-2#TRPBFLT6700CS6-2#PBFLT6700CS6-2#TRMPBFLT6700CS6-2#TRPBFLT6700HDCB-2#PBFLT6700HDCB-2#TRMPBFLT6700HDCB-2#TRPBFLT6700HS6-2#PBFLT6700HS6-2#TRMPBFLT6700HS6-2#TRPBFLT6700IDCB-2#PBFLT6700IDCB-2#TRMPBFLT6700IDCB-2#TRPBFLT6700IS6-2#PBFLT6700IS6-2#TRMPBFLT6700IS6-2#TRPBFLT6700MPDCB-2#PBFLT6700MPDCB-2#TRMPBFLT6700MPDCB-2#TRPBFLT6700MPS6-2#PBFLT6700MPS6-2#TRMPBFLT6700MPS6-2#TRPBF
CM Range(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)(V- -0.3V) to (V- +18V)
Количество каналов222222222222222222222222
Design ToolsLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice ModelLTspice Model
Экспортный контрольнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
Основные особенностиComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top InputsComparator, Reference, Over-the-Top Inputs
HysteresisFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixedFixed
Isupply, мА0.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.00570.0057
Рабочий диапазон температур, °Cот 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125
Prop Delay, µs181818181818181818181818181818181818181818181818
Separate O/P SupplyNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNoneNone
Диапазон напряжения питания1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V1.4V to 18V
Vos, мВ666666666666666666666666
Vs макс., В181818181818181818181818181818181818181818181818
Vs мин., В1.41.41.41.41.41.41.41.41.41.41.41.41.41.41.41.41.41.41.41.41.41.41.41.4
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместим
LT6700 LT6700-1 LT6700-3 LT6700HV-1 LT6700HV-2 LT6700HV-3
Design Notes
  • Dual Micropower Comparator with Integrated 400mV Reference Simplifies Monitor and Control Functions &mdash DN321
    PDF, 76 Кб, Файл опубликован: 3 сен 2003
  • An Autoranging True RMS Converter &mdash DN339
    PDF, 77 Кб, Файл опубликован: 1 июн 2004
  • Signal Conditioning > Comparators > Micropower Comparators | Application Specific Comparators
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Comparators
На английском языке: Datasheet Linear Technology LT6700-2
Публикации по теме
