Datasheet Linear Technology LT6700-3 — Даташит
Серия | LT6700-3 |
Маломощный, низковольтный, двойной компаратор с опорным напряжением 400 мВ
Datasheet LT6700, LT6700HV
PDF, 461 Кб, Язык: анг., Файл закачен: 7 авг 2017, Страниц: 20
Micropower, Low Voltage, Dual Comparator with 400mV Reference
Купить LT6700 на РадиоЛоцман.Цены — от 2.00 до 424 ₽ 20 предложений от 20 поставщиков Analog Comparators LT6700 - Micropower, Low Voltage, Dual Comparator with 400mV Reference | |||
LT6700HVHS6-1 | 2.00 ₽ | ||
LT6700IS6-3 Linear Technology | 140 ₽ | ||
LT6700CS6-3 | 298 ₽ | ||
LT6700CS6-3 Linear Technology | по запросу |
Parameters / Models | LT6700CDCB-3#PBF | LT6700CDCB-3#TRMPBF | LT6700CDCB-3#TRPBF | LT6700CS6-3#PBF | LT6700CS6-3#TRMPBF | LT6700CS6-3#TRPBF | LT6700HDCB-3#PBF | LT6700HDCB-3#TRMPBF | LT6700HDCB-3#TRPBF | LT6700HS6-3#PBF | LT6700HS6-3#TRMPBF | LT6700HS6-3#TRPBF | LT6700IDCB-3#PBF | LT6700IDCB-3#TRMPBF | LT6700IDCB-3#TRPBF | LT6700IS6-3#PBF | LT6700IS6-3#TRMPBF | LT6700IS6-3#TRPBF | LT6700MPDCB-3#PBF | LT6700MPDCB-3#TRMPBF | LT6700MPDCB-3#TRPBF | LT6700MPS6-3#PBF | LT6700MPS6-3#TRMPBF | LT6700MPS6-3#TRPBF |
CM Range | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) | (V- -0.3V) to (V- +18V) |
Количество каналов | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Design Tools | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model | LTspice Model |
Экспортный контроль | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет | нет |
Основные особенности | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs | Comparator, Reference, Over-the-Top Inputs |
Hysteresis | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed | Fixed |
Isupply, мА | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 | 0.0057 |
Рабочий диапазон температур, °C | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от 0 до 70 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 125 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -40 до 85 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 | от -55 до 125 |
Prop Delay, µs | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 |
Separate O/P Supply | None | None | None | None | None | None | None | None | None | None | None | None | None | None | None | None | None | None | None | None | None | None | None | None |
Диапазон напряжения питания | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V | 1.4V to 18V |
Vos, мВ | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
Vs макс., В | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 |
Vs мин., В | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 | 1.4 |
LT6700CDCB-3#PBF | LT6700CDCB-3#TRMPBF | LT6700CDCB-3#TRPBF | LT6700CS6-3#PBF | LT6700CS6-3#TRMPBF | LT6700CS6-3#TRPBF | LT6700HDCB-3#PBF | LT6700HDCB-3#TRMPBF | LT6700HDCB-3#TRPBF | LT6700HS6-3#PBF | LT6700HS6-3#TRMPBF | LT6700HS6-3#TRPBF | LT6700IDCB-3#PBF | LT6700IDCB-3#TRMPBF | LT6700IDCB-3#TRPBF | LT6700IS6-3#PBF | LT6700IS6-3#TRMPBF | LT6700IS6-3#TRPBF | LT6700MPDCB-3#PBF | LT6700MPDCB-3#TRMPBF | LT6700MPDCB-3#TRPBF | LT6700MPS6-3#PBF | LT6700MPS6-3#TRMPBF | LT6700MPS6-3#TRPBF | |
RoHS | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим | Совместим |
LT6700 LT6700-1 LT6700-2 LT6700HV-1 LT6700HV-2 LT6700HV-3
Design Notes
- Dual Micropower Comparator with Integrated 400mV Reference Simplifies Monitor and Control Functions &mdash DN321PDF, 76 Кб, Файл опубликован: 3 сен 2003Выписка из документа
- An Autoranging True RMS Converter &mdash DN339PDF, 77 Кб, Файл опубликован: 1 июн 2004Выписка из документа
Серия: LT6700-3 (24)
- LT6700CDCB-3#PBF LT6700CDCB-3#TRMPBF LT6700CDCB-3#TRPBF LT6700CS6-3#PBF LT6700CS6-3#TRMPBF LT6700CS6-3#TRPBF LT6700HDCB-3#PBF LT6700HDCB-3#TRMPBF LT6700HDCB-3#TRPBF LT6700HS6-3#PBF LT6700HS6-3#TRMPBF LT6700HS6-3#TRPBF LT6700IDCB-3#PBF LT6700IDCB-3#TRMPBF LT6700IDCB-3#TRPBF LT6700IS6-3#PBF LT6700IS6-3#TRMPBF LT6700IS6-3#TRPBF LT6700MPDCB-3#PBF LT6700MPDCB-3#TRMPBF LT6700MPDCB-3#TRPBF LT6700MPS6-3#PBF LT6700MPS6-3#TRMPBF LT6700MPS6-3#TRPBF
- Signal Conditioning > Comparators > Micropower Comparators | Application Specific Comparators
- Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Comparators
